DJI Gamora
MetaFlexa Posted at 4-7 20:49
Thanks for the reply. I start in N mode and then switch to C. My C setting for gimbal is set much slower than N. And when I am on the ground and the drone is idle then the gimbal tilt movement is working perfectly and is very slow. But when I get in the air and start recording then it seems to reset and tilt becomes very fast. All the other Expo & Gain settings work perfectly. It’s just the tilt which changes when in flight and recording. It worked perfectly before the latest firmware update. Thanks
Hi, MetaFlexa. Thank you for the detailed information. Have you tried Drone.Hunter's suggestion? If the issue persists kindly provide us with the following information for further checking:
• Screen recording showing the issue (including the settings made and when the issue occurs).
• DJI RC Logs.
Here's how to get the DJI RC Logs:
Tool preparation:
1. Be sure to install DJI Assistant 2 (Consumer Drones Series) on a computer.
2. Use the USB 3.0 Type-C cable
Operating steps:
1. Power on the DJI RC remote controller and connect it to the computer using the USB 3.0 Type-C cable.
2. Launch DJI Assistant 2 (Consumer Drones Series)
3. After DJI Assistant 2 identifies the DJI RC remote controller, click the connected device name icon.
4. Go to the Menu page and select [Log Export] in the left menu. Next, click the data to be exported and select [Save To Local].
5. After selecting the storage path, please wait until the downloading and compression have been completed.
• Tested time.
Once the required information has been completed, kindly upload the file/s to Dropbox or Google Drive and provide us the shareable link via PM. |
