Fly App crashes when opening ALBUM
1844 19 2023-4-7
QpM
Flight distance : 192589 ft
The problem of crashes of the Fly App appears to be a regular problem!
Once again, I am unable to open the Album in the Fly App.
It does open, then loads the images and then suddenly stops.
Then the Fly App restarts automatically but again opening the Album
continues to cause the problem.
I've already reinstalled the Fly App (ver. 1.9.9 / running on Redmi Note 8 Pro and Android 11) several times (with and without Storage and Cache clearing) and also rebooted the phone. But the problem persists, I can't open the Album or view Photos or Videos?
Some time ago, previous procedure solved the problem but now it no longer works!
Very annoying!
Who knows a solution?
Regards,
QpM
2023-4-7
DJI Tony
Hi, QpM. Thanks for reaching out, and we're sorry for the inconvenience. May we ask what specific mobile phone you're using and its current version? We'll be waiting for your update. Thank you.
2023-4-7
QpM
Hi DJI Tony,
Thank you for your response.
As already stated in my previous post it is a Redmi Note 8 Pro running on Android 11.
It has always worked with the occasional problem as described.
But now completely deleting App, Cache and Storage and reinstalling the App (downloaded from DJI site) does not help.
Happy to read your advice.
2023-4-8
DJI Tony
QpM Posted at 4-8 00:38
Hi DJI Tony,
Apologies for missing the phone model, and thanks for the update. We will send you a PM to gather data for the analysis. Kindly check your inbox, and respond at your earliest convenience. Thank you.
2023-4-8
rafa.g
Portugal
Hi,
The problem as been solved?
Because im having the same problem with my dji mini 2 and redmi note pro 8, and i can't find a solution.
2023-4-11
QpM
No the problem is definitely not solved yet.
I have been asked by PM to send all kinds of information but haven't had time to send it yet.
2023-4-11
rafa.g
Portugal
I can't believe the I will have to buy a new phone so I can be able to use the app without problems ... that's definitely not a good solution ... so many people talking about the same problem over all this years and I don't see any solution anywhere from dji
2023-4-11
djiuser_4llHUrHmHayd
Flight distance : 129547 ft
Greece
Same problem here with redmi note 8 pro.
I have the drone for fifteen days and since yesterday I can't access the gallery, crashes immediately and it restarts the app.
Reinstalled the app
Cleared memory card
Cleared phone and app catche
Any updates on the issue
This is really frustrating
2023-4-22
DJI Tony
djiuser_4llHUrHmHayd Posted at 4-22 13:06
Reinstalled the app
Hi there. Thanks for notifying us about this concern. We're sorry you're experiencing such issues. We'll be sending you a PM to gather details for further investigation. Kindly check at your earliest convenience. Thank you.
2023-4-22
QpM
Meanwhile, it seems to partially work again, after deleting some old recordings (but no effect!).
After some new recordings, the App seems to do it again as long as I don't scroll to older recordings! Very strange!
So it's not quite right yet, but I also haven't sent any information to DJI Tony yet!
This is because I am getting a bit tired of contacts with DJI service!
Lots of messages but no real solutions to stated problems in the past year (only 3 times!!! new (replacement/refurbished?) drone and still same problem!). In 2 years, I had 5 times Mini 2 Fly more combos and all with same problem of skewed horizon in 9x9 Wide Angele Panorama mode.
Nothing was ever fixed by DJI  .
But this has nothing to do with DJI Tony !
2023-4-27
1rafaelf
Flight distance : 8428 ft
Portugal
I have the same problem. Redmi note 8 PRO, with mini 2 SE.
I've had the drone for 2 days, today I went to see the ALBUM and it closes soon.
Is there already a solution?
Thanks
2023-8-29
QpM
Hello 1rafaelf ,
Since a phone reset, the DJI Fly app works again.
I have reset the phone to factory settings and set it up again.
There may have been conflicting apps. But not sure.
But the most important thing is that it works again.
With greeting
2023-8-29
DJI Tony
1rafaelf Posted at 8-29 07:16
Hello there. Thank you for reaching out. You can also try the steps below:
(1)   Please clear the mobile phone cache and ensure that the mobile phone has enough storage available (10G or more is recommended). Hard restart the mobile phone.
(2)Check the App version, if the app is not the latest version, then it is recommended to update the app to the latest version or reinstall it. You can download it here: https://www.dji.com/mini-2-se/downloads
Please keep us posted. Have a great day ahead.
2023-8-30
grundyoso
I am having this problem on a Realme 6 running Android 11. The app was working fine with album view-ability for photos and videos for weeks but then suddenly started crashing... I have been able to get the media off the drone using DJI app on my iPhone but this is painful to do while traveling.  Any updates on this??
Here's the Android Logcat output:
01-09 15:31:52.382  5334  5334 E DJILaunchUtil: [5334]ActivityLifecycle activity created=com.dji.playback.main.PlaybackMainActivity@8e3f080 taskId=214
01-09 15:31:52.400  1660  4520 I InputDispatcher: Focus left window: Window{66f9f2a u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity} in display 0
01-09 15:31:52.400  1660  4520 I InputDispatcher: Window went away: Window{66f9f2a u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity}
01-09 15:31:52.496  5334  5334 E DJIPlayback: │ com.dji.playback.internal.livedatabase.share.SharedViewModel.g0(SourceFile:3)
01-09 15:31:52.496  5334  5334 E DJIPlayback: │ com.dji.playback.internal.livedatabase.share.SharedViewModelFactory.create(SourceFile:7)
01-09 15:31:52.496  5334  5334 E DJIPlayback: │ com.dji.playback.main.PlaybackMainActivity.H4(SourceFile:9)
01-09 15:31:52.496  5334  5334 E DJIPlayback: │ com.dji.playback.main.PlaybackMainActivity$AjcClosure1.run(SourceFile:1)
01-09 15:31:52.496  5334  5334 E DJIPlayback: │ com.dji.component.application.CheckPermissionAOP.e(SourceFile:5)
01-09 15:31:52.496  5334  5334 E DJIPlayback: │ com.dji.playback.main.PlaybackMainActivity.onCreate(SourceFile:1)
01-09 15:31:52.583  5334  5334 I chatty  : uid=10313(dji.go.v5) identical 3 lines
01-09 15:31:52.585  5334  5334 I chatty  : uid=10313(dji.go.v5) identical 24 lines
01-09 15:31:52.601   875  3219 I SurfaceFlinger: [SF client] NEW(0xb400007202c835c0) for (5334:dji.go.v5)
01-09 15:31:52.605  1660  4629 D OppoDisplayPolicy: dji.go.v5, no change cutoutMode: 2
01-09 15:31:52.607   875  1513 D DispPerfService: get hint proc=c1a0952 dji.go.v5, idx=0 none
01-09 15:31:52.609  5334  5334 I chatty  : uid=10313(dji.go.v5) identical 4 lines
01-09 15:31:52.716  1660  4629 D OppoDisplayPolicy: dji.go.v5, no change cutoutMode: 2
01-09 15:31:52.716  1660  4629 I WindowManager: Relayout Window{c1a0952 u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity}: oldVis=4 newVis=0 focusMayChange = true
01-09 15:31:52.720   875  1513 D DispPerfService: get hint proc=dji.go.v5, idx=0 none
01-09 15:31:52.722  1660  4629 W WindowManager: Changing focus fromnull to Window{c1a0952 u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity} displayId=0 Callers=com.android.server.wm.RootWindowContainer.updateFocusedWindowLocked:497 com.android.server.wm.WindowManagerService.updateFocusedWindowLocked:6036 com.android.server.wm.WindowManagerService.relayoutWindow:2682 com.android.server.wm.Session.relayout:229
01-09 15:31:52.731   875  1513 I BufferQueueProducer: [dji.go.v5/com.dji.playback.main.PlaybackMainActivity#0](id:36b00000010,api:1,p:5334,c:875) connect(): api=1 producerControlledByApp=false
01-09 15:31:52.760  1660  3317 I InputDispatcher: Window went away: dji.go.v5/com.dji.playback.main.PlaybackMainActivity#0
01-09 15:31:52.781   875   965 D DispPerfService: onframeavailable pid=5334, slot=4, seq=119, name=dji.go.v5:dji.go.v5/com.dji.playback.main.PlaybackMainActivity#0
01-09 15:31:52.797   875  1513 D DispPerfService: get hint proc=Surface(name=ActivityRecord{fe9fb6d u0 dji.go.v5, idx=0 none
01-09 15:31:52.799  1660  1685 D ColorZoomWindowManagerService: adjustWindowCropForLeash start: appToken = ActivityRecord{fe9fb6d u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity t214}
01-09 15:31:52.798   875  1513 D DispPerfService: get hint proc=Surface(name=ActivityRecord{fe9fb6d u0 dji.go.v5, idx=0 none
01-09 15:31:52.801   875  1513 D DispPerfService: get hint proc=Surface(name=ActivityRecord{7e72c02 u0 dji.go.v5, idx=0 none
01-09 15:31:52.803  1660  1685 D ColorZoomWindowManagerService: adjustWindowCropForLeash start: appToken = ActivityRecord{7e72c02 u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity t214}
01-09 15:31:52.802   875  1513 D DispPerfService: get hint proc=Surface(name=ActivityRecord{7e72c02 u0 dji.go.v5, idx=0 none
01-09 15:31:52.804  1660  1693 I ActivityTaskManager: Displayed dji.go.v5/com.dji.playback.main.PlaybackMainActivity: +454ms
01-09 15:31:52.810  1660  4038 I InputDispatcher: Focus entered window: Window{c1a0952 u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity} in display 0
01-09 15:31:52.811  1660  3315 D OppoDisplayPolicy: dji.go.v5, no change cutoutMode: 2
01-09 15:31:52.830  1660  3316 D InputMethodManagerService: isSecurity: attribute.packageName=dji.go.v5
01-09 15:31:52.838  4043  4043 I GoogleInputMethodService: GoogleInputMethodService.onStartInput():1894 onStartInput(EditorInfo{EditorInfo{packageName=dji.go.v5, inputType=0, inputTypeString=NULL, enableLearning=false, autoCorrection=false, autoComplete=false, imeOptions=0, privateImeOptions=null, actionName=UNSPECIFIED, actionLabel=null, initialSelStart=-1, initialSelEnd=-1, initialCapsMode=0, label=null, fieldId=-1, fieldName=null, extras=null, hintText=null, hintLocales=[]}}, false)
01-09 15:31:52.844  1660  3316 D OppoDisplayPolicy: dji.go.v5, no change cutoutMode: 2
01-09 15:31:53.093  1660  1685 V ColorZoomWindowManagerService: onAnimationFinished:  r = ActivityRecord{7e72c02 u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity t214}
01-09 15:31:53.093  1660  1685 V ColorZoomWindowManagerService: onAnimationFinished:  r = ActivityRecord{fe9fb6d u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity t214}
01-09 15:31:53.094  1660  1685 I ColorAppSwitchManagerService:  handleAppVisible , r = ActivityRecord{fe9fb6d u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity t214}
01-09 15:31:53.109   875   875 D OppoExLayer: ~Layer() sequence=125, name=Surface(name=ActivityRecord{7e72c02 u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity)/@0xc0cb2c4 - animation-bounds#0@0xb400007161e4d000
01-09 15:31:53.109   875   875 D OppoExLayer: ~Layer() sequence=124, name=Surface(name=ActivityRecord{7e72c02 u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity)/@0xc0cb2c4 - animation-leash#0@0xb400007161f0a000
01-09 15:31:53.109   875   875 D OppoExLayer: ~Layer() sequence=123, name=Surface(name=ActivityRecord{fe9fb6d u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity)/@0x425a66f - animation-bounds#0@0xb400007161e41000
01-09 15:31:53.109   875   875 D OppoExLayer: ~Layer() sequence=122, name=Surface(name=ActivityRecord{fe9fb6d u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity)/@0x425a66f - animation-leash#0@0xb400007161e3e000
01-09 15:31:53.112   875  1514 I BufferQueueProducer: [dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity#0](id:36b0000000f,api:1,p:5334,c:875) disconnect(): api=1
01-09 15:31:53.125  1660  4520 I InputDispatcher: Window went away: Letterbox_left_ActivityRecord{7e72c02 u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity t214}
01-09 15:31:53.143  1660  4520 I InputDispatcher: Window went away: dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity#0
01-09 15:31:53.158   875   875 I BufferQueueConsumer: [dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity#0](id:36b0000000f,api:0,p:-1,c:875) disconnect()
01-09 15:31:53.158   875   875 I BufferQueue: [dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity#0](this:0xb4000071621f5458,id:15,api:1,p:-1,c:-1) onDestructor()
01-09 15:31:53.159   875   875 D OppoExLayer: ~Layer() sequence=108, name=dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity#0@0xb400007140455000
01-09 15:31:53.335  5334  5365 I dji.go.v5: Background young concurrent copying GC freed 333764(20MB) AllocSpace objects, 106(2496KB) LOS objects, 57% free, 16MB/39MB, paused 3.543ms total 198.350ms
01-09 15:31:53.511  4064  7551 I MediaProvider: Open with lower FS for /storage/emulated/0/DCIM/DJI Album/dji_fly_20231224_155030_0027_1704063195041_video.mp4. Uid: 10313
01-09 15:31:53.511  4064  4117 I MediaProvider: Open with lower FS for /storage/emulated/0/DCIM/DJI Album/dji_fly_20231224_155012_0026_1704063195786_video.mp4. Uid: 10313
01-09 15:31:53.534  4064  4092 I MediaProvider: Open with lower FS for /storage/emulated/0/DCIM/DJI Album/dji_fly_20231228_160604_0001_1704063193478_video.mp4. Uid: 10313
01-09 15:31:53.538  4064  4090 I MediaProvider: Open with lower FS for /storage/emulated/0/DCIM/DJI Album/dji_fly_20231228_163418_0002_1704063179600_video.mp4. Uid: 10313
01-09 15:31:53.611  5334  7909 I dji.go.v5: Waiting for a blocking GC Alloc
01-09 15:31:53.628  5334  7909 I dji.go.v5: WaitForGcToComplete blocked Alloc on HeapTrim for 17.000ms
01-09 15:31:53.628  5334  7909 I dji.go.v5: Starting a blocking GC Alloc
01-09 15:31:53.634  5334  7910 I dji.go.v5: Waiting for a blocking GC Alloc
01-09 15:31:53.641  1660  1760 V ColorZoomWindowManagerService: prepareZoomTransition: curStack=Task{8fd5c #214 visible=true type=standard mode=fullscreen translucent=true A=10313:dji.go.v5 U=0 StackId=214 sz=2}   nextStackTask{8fd5c #214 visible=true type=standard mode=fullscreen translucent=true A=10313:dji.go.v5 U=0 StackId=214 sz=2}
01-09 15:31:53.649  5334  5334 E DJICrashExecutor: killMySelf: packagename = dji.go.v5
01-09 15:31:53.649  5334  5334 E DJICrashExecutor:         at dji.publics.DJIObject.DJICrashExecutor.c(SourceFile:4)
01-09 15:31:53.649  5334  5334 E DJICrashExecutor:         at com.dji.mainpageui.device.DJIDeviceActivity.onDestroy(SourceFile:8)
01-09 15:31:53.649  5334  5334 E DJICrashExecutor: killMySelf: 0 dji.go.v5
01-09 15:31:53.649  1660  1760 V ColorAthena: kill background: dji.go.v5 is called by dji.go.v5
01-09 15:31:53.675  1660  3316 I InputDispatcher: Focus left window: Window{c1a0952 u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity} in display 0
01-09 15:31:53.675  1660  3316 I InputDispatcher: Window went away: Window{c1a0952 u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity}
01-09 15:31:53.805  1660  4038 D MtkConnectivityService: ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ TRACK_DEFAULT id=68, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Uid: 10313 AdministratorUids: [] RequestorUid: 10313 RequestorPackageName: dji.go.v5] ], android.os.BinderProxy@f8b6c22)
01-09 15:31:53.806  1660  4520 I WindowManager: WIN DEATH: Window{c1a0952 u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity}
01-09 15:31:53.807  1660  4116 D MtkConnectivityService: ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ LISTEN id=59, [ Capabilities: NOT_RESTRICTED&TRUSTED&NOT_VPN Uid: 10313 AdministratorUids: [] RequestorUid: 10313 RequestorPackageName: dji.go.v5] ], android.os.BinderProxy@d9b96b3)
01-09 15:31:53.807  1660  3314 D MtkConnectivityService: ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ LISTEN id=60, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Uid: 10313 AdministratorUids: [] RequestorUid: 10313 RequestorPackageName: dji.go.v5] ], android.os.BinderProxy@49be470)
01-09 15:31:53.807   875  1513 I BufferQueueProducer: [dji.go.v5/com.dji.playback.main.PlaybackMainActivity#0](id:36b00000010,api:1,p:5334,c:875) disconnect(): api=1
01-09 15:31:53.807  1660  2783 D MtkConnectivityService: ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ LISTEN id=61, [ Transports: WIFI Capabilities: NOT_RESTRICTED&TRUSTED&NOT_VPN Uid: 10313 AdministratorUids: [] RequestorUid: 10313 RequestorPackageName: dji.go.v5] ], android.os.BinderProxy@49a93e9)
01-09 15:31:53.808  1660  4520 W InputDispatcher: Attempted to unregister already unregistered input channel 'c1a0952 dji.go.v5/com.dji.playback.main.PlaybackMainActivity (server)'
01-09 15:31:53.815  1660  4520 W WindowManager: Changing focus fromWindow{c1a0952 u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity} to null displayId=0 Callers=com.android.server.wm.RootWindowContainer.updateFocusedWindowLocked:497 com.android.server.wm.WindowManagerService.updateFocusedWindowLocked:6036 com.android.server.wm.RootWindowContainer.performSurfacePlacementNoTrace:866 com.android.server.wm.RootWindowContainer.performSurfacePlacement:850
01-09 15:31:53.824   875   875 D OppoExLayer: ~Layer() sequence=118, name=c1a0952 dji.go.v5/com.dji.playback.main.PlaybackMainActivity#0@0xb400007161e47000
01-09 15:31:53.824  1660  3315 I InputDispatcher: Window went away: dji.go.v5/com.dji.playback.main.PlaybackMainActivity#0
01-09 15:31:53.825  1660  4038 I WindowManager: WIN DEATH: Window{66f9f2a u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity}
01-09 15:31:53.825  1660  4038 W InputDispatcher: Attempted to unregister already unregistered input channel '66f9f2a dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity (server)'
01-09 15:31:53.826   875   875 I BufferQueueConsumer: [dji.go.v5/com.dji.playback.main.PlaybackMainActivity#0](id:36b00000010,api:0,p:-1,c:875) disconnect()
01-09 15:31:53.826   875   875 I BufferQueue: [dji.go.v5/com.dji.playback.main.PlaybackMainActivity#0](this:0xb400007161e2fa58,id:16,api:1,p:-1,c:-1) onDestructor()
01-09 15:31:53.826   875   875 D OppoExLayer: ~Layer() sequence=119, name=dji.go.v5/com.dji.playback.main.PlaybackMainActivity#0@0xb400007161e28000
01-09 15:31:53.833  1660  1760 D TheiaCrashMonitor: dji.go.v5crash
01-09 15:31:53.833  1660  1760 I ActivityManager: Process dji.go.v5 (pid 5334) has died: fg  TOP
01-09 15:31:53.836   856   941 I libPowerHal: [perfNotifyAppState] pack:dji.go.v5, pid:5334, STATE_DEAD
01-09 15:31:53.837  1660  1760 V ColorZoomWindowManagerService: onAnimationFinished:  r = ActivityRecord{fe9fb6d u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity t214 f}}
01-09 15:31:53.840   875   875 D OppoExLayer: ~Layer() sequence=107, name=66f9f2a dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity#0@0xb40000714041f000
01-09 15:31:53.841  1660  3025 I InputDispatcher: Window went away: Letterbox_left_ActivityRecord{fe9fb6d u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity t214}
01-09 15:31:53.841  1660  1660 I OppoPhoneWindowManager: KeyLockModeReceiver KeyLockMode: 0 ProcessName: dji.go.v5
01-09 15:31:53.856  1660  1685 D OppoDisplayPolicy: dji.go.v5, no change cutoutMode: 0
01-09 15:31:53.863  1660  1685 D OppoDisplayPolicy: dji.go.v5, no change cutoutMode: 0
01-09 15:31:53.878   875   875 D OppoExLayer: ~Layer() sequence=117, name=ActivityRecord{fe9fb6d u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity#0@0xb400007161e38000
01-09 15:31:53.879  1660  1699 I ActivityManager: Start proc 7943:dji.go.v5/u0a313 for top-activity {dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity}
01-09 15:31:53.884  7943  7943 E dji.go.v5: Unknown bits set in runtime_flags: 0x40000000
01-09 15:31:53.887  7943  7943 E dji.go.v5: Not starting debugger since process cannot load the jdwp agent.
01-09 15:31:53.901  1660  4629 I InputDispatcher: setFocusedApplication displayId=0 ActivityRecord{7e72c02 u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity t214}
01-09 15:31:53.910  1660  1989 E OplusLocationStatusMonitor: will removedji.go.v5
01-09 15:31:53.910  1660  1989 E OplusLocationStatusMonitor: removedji.go.v5
01-09 15:31:53.911  1660  1685 I WindowManager: Relayout Window{b0d192a u0 Splash Screen dji.go.v5}: oldVis=8 newVis=0 focusMayChange = true
01-09 15:31:53.917   875   965 I BufferQueueProducer: [Splash Screen dji.go.v5#0](id:36b00000011,api:2,p:1660,c:875) connect(): api=2 producerControlledByApp=false
01-09 15:31:53.918  7943  7943 I dji.go.v5: The ClassLoaderContext is a special shared library.
01-09 15:31:53.921  7943  7943 I dji.go.v5: The ClassLoaderContext is a special shared library.
01-09 15:31:53.927   875   965 D DispPerfService: onframeavailable pid=1660, slot=0, seq=130, name=system_server:Splash Screen dji.go.v5#0
01-09 15:31:53.930  1660  1685 D ColorWindowAnimationManager: checkAndLoadCustomAnimation use override anim for  =:dji.go.v5
01-09 15:31:53.944  1660  4629 I InputDispatcher: Window went away: Splash Screen dji.go.v5#0
01-09 15:31:54.095  1660  1685 V ColorZoomWindowManagerService: onAnimationFinished:  r = ActivityRecord{7e72c02 u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity t214}
01-09 15:31:54.095  1660  1685 I ColorAppSwitchManagerService:  handleAppVisible , r = ActivityRecord{7e72c02 u0 dji.go.v5/com.dji.mainpageui.device.DJIDeviceActivity t214}
01-09 15:31:54.142  1660  1684 W ActivityTaskManager: Activity top resumed state loss timeout for ActivityRecord{fe9fb6d u0 dji.go.v5/com.dji.playback.main.PlaybackMainActivity t-1 f}}
01-09 15:31:54.142   856   893 I mtkpower@impl: [notifyAppState] act com.dji.playback.main.PlaybackMainActivity => com.dji.mainpageui.device.DJIDeviceActivity
01-09 15:31:54.436  7943  7943 W dji.go.v5: type=1400 audit(0.0:1475): avc: denied { search } for comm=4173796E635461736B202331 name="ppm" dev="proc" ino=4026531972 scontext=u:r:untrusted_app:s0:c57,c257,c512,c768 tcontext=ubject_r:proc_ppm:s0 tclass=dir permissive=0 app=dji.go.v5
01-09 15:31:54.440  7943  7943 W dji.go.v5: type=1400 audit(0.0:1476): avc: denied { search } for comm=4173796E635461736B202331 name="ppm" dev="proc" ino=4026531972 scontext=u:r:untrusted_app:s0:c57,c257,c512,c768 tcontext=ubject_r:proc_ppm:s0 tclass=dir permissive=0 app=dji.go.v5
01-09 15:31:54.461  7943  7943 I TetheringManager: registerTetheringEventCallback:dji.go.v5
01-09 15:31:54.534  7943  7943 I MMKV    : <MMKV.cpp:206::initializeMMKV> root dir: /data/user/0/dji.go.v5/files/mmkv
01-09 15:31:54.568  7943  7943 W System.err: java.lang.ClassNotFoundException: com.dji.p4upgrade.DJIEventBusIndex
01-09 15:31:54.568  7943  7943 W System.err:         at com.dji.component.application.launch.CommonLaunchHelper.addEventBusIndexs(SourceFile:16)
01-09 15:31:54.568  7943  7943 W System.err:         at com.dji.component.application.AppLaunchProxy.p(SourceFile:11)
01-09 15:31:54.568  7943  7943 W System.err:         at com.dji.component.application.launch.DefaultAppLaunchDelegate.dispatchAppCreate(SourceFile:2)
01-09 15:31:54.568  7943  7943 W System.err:         at com.dji.component.application.launch.DJIAppLaunchProxy.dispatchAppCreate(SourceFile:1)
01-09 15:31:54.568  7943  7943 W System.err:         at com.dji.component.application.DJIApplicationLike.onCreate(SourceFile:1)
01-09 15:31:54.568  7943  7943 W System.err:         at com.dji.component.application.DJIApplication.onCreate(SourceFile:9)
01-09 15:31:54.568  7943  7943 W System.err: Caused by: java.lang.ClassNotFoundException: com.dji.p4upgrade.DJIEventBusIndex
01-09 15:31:56.483  7943  7943 W dji.go.v5: JNI RegisterNativeMethods: attempt to register 0 native methods for dji.fscore.jni.pack.JNIPackHelper
1-9 12:34
spyros258
Flight distance : 45515 ft
Greece
I had the same bug with dji album on Redmi note 8 pro and dji mini 2 se and it appeared suddenly after taking some photos and small videos of 2.7k.  When this bug happens, uninstalling and reinstalling new and old app versions doesn't fix this.  When press the album it opens and  after 2 sec crashes and app restarts, even without sd card and even without connecting to the aircraft. The fix in this case is to delete all these latest photos and videos from the phone gallery (better and from the sd card) taken by the drone that caused the bug and then turn off synchronization at camera settings. It's not needed to reset all phone for this.   To me there was 1 small video and 2 photos (not bugged or corrupted) that i had to delete from the phone gallery to fix the crash of dji album.
3-18 10:38
DJI Tony
spyros258 Posted at 3-18 10:38
Hi there. Sorry about the trouble you experienced. You can clear just the materials on the DJI Album on your mobile device by going to Albums > Other Albums > DJI Album. I hope this helps. Have a nice day.
3-18 22:09
fansdd25b87f
Greece
Thanks! Yes that is even easier to delete these latest photos from the dji album of phone
4-6 03:53
DJI Paladin
Flight distance : 318 ft
fansdd25b87f Posted at 4-6 03:53
You're welcome, spyros258. Should you have other inquiries, feel free to contact us. Thank you for your valued support.
4-6 20:56
Giampiero Prinzis
Same problem on iPhone 8
4-21 08:49
DJI Paladin
Giampiero Prinzis Posted at 4-21 08:49
Hi there. Thank you for reaching out and we do apologize for the trouble. Please confirm what DJI App are you using, the DJI Go 4 app or the DJI Fly app. If you are using the DJI Fly app, kindly reinstall the app on your mobile device and check if the issue persists. If yes, please upload a screen recording showing the issue for us to further isolate the issue. Please keep us posted.
4-22 03:54
