Firmware update problem on my new Inspire !
1500 10 2015-8-23
7209459
Russia
Hello!
Yesterday I bought quadrocopter Inspire 1. Unpack gathered, stitched controller then put mikroSD firmware into the camera, turn the power on. Sound D-D-D-D sounded about 15 minutes, then the sound will change. I waited another 15 minutes and turned off quadrocopter. After that, I check the log. it is written there
[00004220][01 00] Firmware upgrade finished successfully.
[00004586]Done.
[00004621]Packet [C:\WM610_FW_V01.03.00.00.bin] resumed, card sn [0x50ce3e64].
[00004662]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004742]Version checking[2]...
[00004784][01 00][05] v1.19.3422 -> v1.19.3422
[00004834][01 01][00] v1.13.3166 -> v1.19.3422 need upgrade
[00004917][03 05][00] v34.1.0.5 -> v34.1.0.5
[00004997][03 06][00] v2.0.5.14 -> v2.2.6.33 need upgrade.
[00005039][04 00][00] v1.16.0.76 -> v1.26.0.3 need upgrade.
[00005137][05 00][00] v2.5.6.1 -> v3.0.6.1 need upgrade.
[00005182][08 00][00] v1.12.0.21 -> v1.14.0.25 need upgrade.
[00005297][09 00][00] v1.7.0.3 -> v1.8.0.0 need upgrade.
[00005359][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00005477][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005577][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005677][12 02][00] v1.8.0.0 -> v1.8.0.0
[00005776][12 03][00] v1.8.0.0 -> v1.8.0.0
[00005900][15 00][00] v1.1.1.0 -> v1.1.2.0 need upgrade.
[00005956][17 00][00] v1.1.0.1 -> v1.1.0.4 need upgrade.
[00006057][17 01][00] v2.0.0.1 -> v2.0.0.8 need upgrade.
[00006106][19 00][00] v1.0.8.96 -> v1.0.8.96
[00006145]Done.
[00006178]Firmware upgrading[2]...
[00006339][01 01] Firmware upgrade start...
[00036640][01 01] Firmware upgrade finished successfully.
[00037497][08 00] Firmware upgrade start...
[00527797][08 00] Firmware upgrade finished successfully.
[00528021][03 06] Firmware upgrade start...
[00751747][03 06] Firmware upgrade finished successfully.
[00751809][17 00] Firmware upgrade start...
[00813062][17 00] Firmware upgrade finished successfully.
[00813114][17 01] Firmware upgrade start...
[00866737][17 01] Firmware upgrade finished successfully.
[00866781][11 00] Firmware upgrade start...
[00947489][11 00] Firmware upgrade finished successfully.
[00947545][05 00] Firmware upgrade start...
[00991925][05 00] Firmware upgrade finished successfully.
[00991971][15 00] Firmware upgrade start...
[00994489][15 00] Firmware upgrade finish failed (step = 5, err = 0xff, sum = 0xcc08).
[01024635][09 00] Firmware upgrade start...
[01079649][09 00] Firmware upgrade finished successfully.
[01079722][04 00] Firmware upgrade start...
[01142005][04 00] Firmware upgrade finished successfully.
[01142040]Done.
[01142076]Version checking[3]...
[01142113][01 00][05] v1.19.3422 -> v1.19.3422
[01142148][01 01][05] v1.19.3422 -> v1.19.3422
[01142199][03 05][00] v34.1.0.5 -> v34.1.0.5
[01142319][03 06][05] v2.2.6.33 -> v2.2.6.33
[01142359][04 00][05] v1.26.0.3 -> v1.26.0.3
[01142440][05 00][05] v3.0.6.1 -> v3.0.6.1
[01142489][08 00][05] v1.14.0.25 -> v1.14.0.25
[01142535][09 00][05] v1.8.0.0 -> v1.8.0.0
[01142600][11 00][05] v3.7.15.9 -> v3.7.15.9
[01142680][12 00][00] v1.8.0.0 -> v1.8.0.0
[01142780][12 01][00] v1.8.0.0 -> v1.8.0.0
[01142880][12 02][00] v1.8.0.0 -> v1.8.0.0
[01142962][12 03][00] v1.8.0.0 -> v1.8.0.0
[01152344][15 00][06] device not detected.
[01152399][17 00][05] v1.1.0.4 -> v1.1.0.4
[01152519][17 01][05] v2.0.0.8 -> v2.0.0.8
[01152563][19 00][00] v1.0.8.96 -> v1.0.8.96
[01152597]Packet upgrade failed at version checking.
what should I do?
2015-8-23
tapboxer
Flight distance : 824672 ft
looks like is already done. Whats wrong, have you try to fly it?
2015-8-23
7209459
Russia
camera not working.
2015-8-23
ageelectrical
Could it have been the camera was not fitted correctly ,it seams that their is problems with the repeated connection and disconnection I'm wondering maybe not all the pins we reconnecting correctly
Could be the data transfer and camera pins are separate  ,you may need  clean and refit and reinstall  after which you'll have to return it for repair goodluck
2015-8-23
7209459
Russia
I tried to reinstall the camera several times. No results ... Is there any way forced camera firmware?
2015-8-23
dandmpetro
I don't think its your inspire.  Its the RC Have you updated that
2015-8-23
7209459
Russia
Service says that it is camera fault. Maybe cables of camera.
2015-8-24
retret66
same thing happens to me...return it..The no device detected is a problem
2015-8-25
7209459
Russia
Local dealer will replace me a new camera, but the problem remained. Images from the camera is not present, the firmware is not updated.
2015-8-29
teamnest1
Flight distance : 18484 ft
I wonder what it might be. I am in the same boat. I am going to check the camera cables.
2015-8-29
retret66
7209459 Posted at 2015-8-29 04:14
Local dealer will replace me a new camera, but the problem remained. Images from the camera is not  ...
There is a blog that is having the same problem and it is not the camera, DJI replaced his flight controller. Make sure you read all his update..
No Signal Blog
Dear Joel, Your Inspire 1 has been repaired. The technician replaced the flight controller. Your craft has been updated, test flown and is fully operational.
2015-8-30
