JJB*
Flight distance : 12260774 ft
Hi all,
Recently in 2 discussions.
- how to interpret a flightlog where the remote pilot pushed the sticks in CSC position.
- Hover stability and height control low over water....
In the CSC discusion the flightlog showed only 1 record, the very last record, with a CSC.
In the Hover stability discusion, all about wich sensors for horizontal stabilily and wich for height control.
FIRST discussion
What will happen do a DJI drone in CSC ?? [ time for tests and numbers in flightlogs! ]
First : 2 setings in the Advanced Safety Settings for CSC
- EMERGENCY ONLY >> CSC will stop motors if DJI sofware is determine a 'emergency' *
- Anytime (Use with caution). >> will stop motors after 1.5 second. ALWAYS!
situation1: So what if remote pilot CSC a drone with setting EMERGENCY ONLY ? drone will descend and circling down.
situation2: So what if remote pilot CSC a drone with setting ANYTIME? Obvious, drone will stop motors and falling out if the sky.
In the charts you see a CSC in both situations.
Nice to know (i wasn`t aware of this) that in ANYTIME drone will not power off completely (just motor stop), plus in the flightlog for 1.5 seconds the CSC is registerd.
Ofcourse when there is not excactly at the same time a connection error at start of the CSC!
(after motor stop flightlog recording is stopped as well, same as in a normal flight/ landing)
Second discussion
Horizontal positioning by GPS, with some aid from the bottom vision sensor if within range.
Vertical height control by barometric sensor and....does the InfraRed height sensor aid this stability??
Flying low over water sometimes height control goes weird...i see often in such logs an intermittent or no signal on the IR sensor.
[ nice to know! that PhantomHelp CSV copy paste the last height into next records until sensor is measuring height again ]
Time for a another test....
I tested my MINI2 flying low above grass, vision sensor duct taped : could not see difference to flying without covering the vision sensor (need to do it again few times)
Tested with vision sensor and IR sensor duct taped. OMG, see the height control performance in the video and in the chart!
Happy many landings, [ hope that you understand my chinese english :-) ]
cheers
JJB [ Charts by FRAP ; the 'best' software for flightlog analysis ]
