mavic air error code null 255
17910 27 2023-4-15
AndreaDolomites
Hi
I turned on my drone after not using it for some time
my drone is a mavic air
They made me download a new application ( dji drone ) for the Android system
when I want to fly, the drone stays with red lights and I can't fly
can you help me?
Thank you
2023-4-15
DJI Tony
Hi, AndreaDolomites. Thanks for reaching out, and apologies for the inconvenience. Can you confirm what specific new app did you download? Mavic Air must use the DJI GO 4 app. Kindly post a screenshot of the error message for further checking. Thank you.
2023-4-15
AndreaDolomites
DJI Tony Posted at 4-15 05:50
the dji go 4 was the app i used before
they made me download this:
2023-4-15
AndreaDolomites
AndreaDolomites Posted at 4-15 05:57
they made me download this:[view_image]
I use a galaxy a32 smartphone
2023-4-15
AndreaDolomites
AndreaDolomites Posted at 4-15 06:01
I managed to solve.
thank you all the same for your support
2023-4-15
DJI Tony
AndreaDolomites Posted at 4-15 06:56
I managed to solve.
Thanks for the update. We're glad to hear that! Did you manage to resolve the issue by installing the DJI Go 4 app? Thank you.
2023-4-15
AndreaDolomites
DJI Tony Posted at 4-15 21:54
yes I downloaded dji go 4 but
I had to download it from the dji site because it was no longer available from the android market
2023-4-15
DJI Tony
AndreaDolomites Posted at 4-15 22:14
Thanks for the update. Yes, currently, DJI apps cannot be downloaded from Google Play store due to compatibility reasons. We appreciate your understanding.
2023-4-16
djiuser_4aBza3VWwPEE
Colombia
Mi dron presenta null 255  me pueden ayudar
2023-5-3
AndreaDolomites
djiuser_4aBza3VWwPEE Posted at 5-3 08:50
What smartphone do you use to fly your drone? and what model of drone do you have?
2023-5-3
ronald delos reyes
Philippines
Good day,
Pls be advised that after downloading the new dji drone app, i can not fly anymore my mavic air drone.  The error is null 255. I used to fly my drone with my smartphone/samsung/android with the old Dji 4 app.
Kindly advise
Thank you.
2023-6-2
ronald delos reyes
Philippines
I managed to solve.
Hi Andrea,
Re your problem with the new dji drone app, i had the same problem as per yours.
Could you please advise what did you do to manage the said problem.
Your response will be highly appreciated.
Thank you.
2023-6-2
AndreaDolomites
You need to connect your drone to your PC/Mac and do an update with the dji assistant software 2.
Then on your smartphone you need to download the dji go app 4.
You need to download it from the DJI website with a browser and not from the store
2023-6-3
ronald delos reyes
Philippines
Hi Andrea good day.
Thank you for yr below msg, successfully updated my software as well as the Dji 4 app. However, failed to calibrate IMU (pls see attached).
Kindly advise if you have any idea with this.
Thank you.
2023-6-21
ronald delos reyes
Philippines
ronald delos reyes Posted at 6-21 18:55
Hi Andrea good day.
[Image]
Hi Andrea,
Re my last kindly disregard since i was able to solved the said trouble.
Thank you.
2023-6-27
Arthuro TDV
Mexico
Tuve el mismo problema con el dron MAVIC AIR. Lo he querido volar pero igual me indica NULL 255. Lo instalé en un samsung A54.
2023-11-14
DJI Tony
Arthuro TDV Posted at 11-14 10:18
Hi, Arthuro TDV. May I know what application you downloaded? Please make sure it's the DJI Go 4 app. It is not available on Google Play but can be downloaded from the DJI official website. You can use this link to get to the download page: https://www.dji.com/downloads/djiapp/dji-go-4. Please keep me posted. Have a great day.
2023-11-14
djiuser_p0Jrkjf6npvS
Hello
I just started with my drone and I got everything connected but I get the null:225 error.
Can someone help?
2024-1-5
DJI Tony
djiuser_p0Jrkjf6npvS Posted at 1-5 12:35
Hello
Can someone help?
Hello there. Sorry about the trouble. Can you please show us a screenshot of the error and the app you are using? Thank you very much.
2024-1-5
Adam Nico
Hello I have a Maverick Pro 2 and I am experiencing issues. First it said System error check at but in the app there is nothing to check and it is very limited to what I can actually do in the app. I can get the Drone to connect sometimes and when it finally does and it goes back to GPS mode I go to the go fly button push it and slide over to Launch and it says null 255 before this it was giving me a system error message that has since gone away. I'm currently using the older DJI app because the new DJI Go app only shuts down when I hit go fly so I'm having multiple issues and could use some help and direction thank you very much
2024-3-23
DJI Tony
Adam Nico Posted at 3-23 14:08
Hi Adam. Thank you for reaching out. Will it be fine if you post a screenshot of the app or the error from the app? I appreciate your patience.
2024-3-23
Claudio Patricio Emanuel CORVELA
Argentina
Hola buen día tengo un dji mini2, después d un tiempo de no usarlo me apareció null255 , luego lo puede resolver nosé intentando eliminar y volver a descargar la app.   Pero ahora lo que me pasó és que se cayó de no más de 3 metros y me sigue apareciendo ese error
2024-7-14
DJI Diana
Flight distance : 2408 ft
Claudio Patricio Emanuel CORVELA Posted at 7-14 03:34
Hi there,
thank you for reaching out.
About the app, are you referring to DJI Fly app? If yes, you can download for free on the DJI official website. Please click the link to download it: https://www.dji.com/downloads/djiapp/dji-fly
Also, could you please provide us with a screenshot to check the error code?
Looking forward to your reply. Thank you.
2024-7-14
Argentina
DJI Diana Posted at 7-14 04:06
Hi there,
2024-7-14
Jay Smith2
DJI Tony Posted at 2023-4-15 05:50
I am having the same issue. Error code null:255
I tried downloading dji go 4 off the website but it stays on download pending. What am i doing wrong?
2024-9-18
DJI Tony
Jay Smith2 Posted at 9-18 15:22
Hi there. Please ensure that the download website is correct, then replace the network to have a try.
If you still can not download the DJI GO 4 APP, please tell us and we will further trouble shoot for you.
2024-9-19
Antdrones
Flight distance : 1253035 ft
AndreaDolomites Posted at 2023-4-15 06:56
I managed to solve.
2024-9-19
John Rey Dela Cruz
Philippines
My dji spark was showing null 255 every time i swipe the go fly
2024-9-25
