DJI Mini 2 SE MSDK support?
472 6 2023-4-19
Kereplaz
Flight distance : 1846736 ft
Lithuania
Hello, when can we expect DJI Mini 2 SE added to the older MSDK supported drones list? It is almost identical to the Mini 2 which is supported and I bought this drone for the reason of using it with some other apps. It has been quite some time since the Mini 2 Se release.
2023-4-19
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. As of the moment, the DJI Mini 2 SE doesn't support the SDK function. However, I will forward this suggestion of yours to our designated team for your attention. After the evaluation of the engineers, significant suggestions or requests will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news on our DJI official website at www.dji.com. Thank you for your valued support!
2023-4-19
DAFlys
From the developer site - https://sdk-forum.dji.net/hc/en- ... er-1-Hello-MSDK-V5-
Currently, MSDK V5 only supports the M30 series, M300RTK, Mavic 3 enterprise series and Mini 3/Mini 3 Pro. It will support future products later but no old products.
2023-4-19
Kereplaz
Lithuania
DAFlys Posted at 4-19 23:27
From the developer site - https://sdk-forum.dji.net/hc/en-us/articles/5976502476441-Chapter-1-Hello-MSDK-V5-
Mini 2 SE is an identical drone to the Mini 2 which has older MSDK support and the SE should as well. I am not concerned about the new one in regards to this drone.
2023-4-20
DAFlys
Kereplaz Posted at 4-20 02:55
It's not identical.   Its feature reduced to cover the lower cost.
2023-4-20
Kereplaz
Lithuania
DAFlys Posted at 4-20 21:44
Identical hardware-wise. The video format limitation is a software block and does not impact MSKD support in any way.
2023-4-21
DAFlys
Kereplaz Posted at 4-21 03:50
Perhaps the SDK is also something thats dropped spot that theres diversion between the two products.
2023-4-22
