Screen on Controller became almost white, inverted
2818 18 2023-4-21
Stephen Carney
Flight distance : 70873 ft
hi, I was filming last week, all was going well, ws up at 35M Filming a lawn bowls game,
then the screen went white, I could only see some parts that were darker,
Looked like it was inverted where dark becomes etc.
The videos themselves are exactly the same, the camera is reporting the shot inverted
As though I've pressed a button by mistake to incert the screen and shots
Any suggestions thanks
NOTE
It happens only when I change Batteries, happened after  I did some updates the day before, perhaps my batteries are not all updated
2023-4-21
DJI Gamora
Hi, Stephen. Thank you for reaching out. What kind of RC do you have? Can you please provide us with the sample video/s for further checking? Kindly upload the video/s to a shareable link then you may send the link to us via PM. We will wait for your reply. Thank you.
2023-4-21
Stephen Carney
RC is a DJI RC Smart Controller
I was video'ing this landed,  changed battery and it then became a Negative image (could not think of that word this morning)
will upload one of the one where it happened and share the link
2023-4-21
Stephen Carney
Don't have anywhere to post the video too except YouTube and  that takes time
It happened as soon as I changed the battery !!!! could that cause this to happen ?
2023-4-21
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
RE: Screen on Controller became almost white, inverted
Stephen Carney Posted at 4-21 20:47
I was video'ing this https://youtu.be/nRnpO27HLjU landed,  changed battery and it then became a Negative image (could not think of that word this morning)
And where did you have the problem? Everything is fine in this video.
2023-4-21
Burt37
Flight distance : ****
I had this happened to me once the first day with the Mini3pro and the RC...
Perhaps I changed the white balance to Auto in the settings... It has never happened again after that...
2023-4-22
Stephen Carney
it happens when I change the battery, so thought to put the No. 1 Battery back in and see...... and yes its fine again..... EUREKA
Its only happens when I use another battery,
Has something to do with how I installed the updates, is there a correct way to update batteries?
2023-4-22
Mobilehomer
Flight distance : 18150351 ft
Stephen Carney Posted at 4-22 10:28
Put battery 2 back in, then check for updates. The battery may need updating.
2023-4-22
Stephen Carney
Will do when I get time
2023-4-22
Labroides
Flight distance : 26781877 ft
Burt37 Posted at 4-22 02:05
That's got nothing to do with white balance, whether it's set to auto or anything else.
2023-4-22
Burt37
Labroides Posted at 4-22 16:29
I can hear you, but I did something and it did fix my overexposed screen... or maybe it was the ISO... Like I said, I wasn't sure but I did change one of these in the setting and the screen when back to normal. I definitely didn't change the battery...
2023-4-22
Labroides
Burt37 Posted at 4-22 16:54
White balance has nothing to do with overexposure.
They are completely unrelated.
White balance set incorrectly would make the image appear too blue or too yellow.
Incorrect exposure makes the image too dark or washed out.
The OP's description is vague but sounds most like incorrect exposure setting.
Without more and better information, it's not possible to tell what his issue actually was except that it had nothing to do woth batteries or firmware.
2023-4-22
Burt37
Labroides Posted at 4-22 16:58
How do you achieve incorrect exposure when the camera is set to manual?
2023-4-22
Labroides
Burt37 Posted at 4-22 17:03
Your question is odd ... it sounds like you aren't familiar with basic photography basics?
If you manually set incorrect exposure settings, you've achieved incorrect exposure.
2023-4-22
Burt37
Labroides Posted at 4-22 17:27
Ok, let's try a different entrance...
If I got the camera set to manual and I got the wrong ISO setting for that location, lets say 1600 and I turn the drone towards the sun.. What would my screen looks like? Washed out? Really white?
2023-4-22
Labroides
Burt37 Posted at 4-22 17:35
Sorry ... I can't follow what you are trying to say or how it relates to this thread.
2023-4-22
Burt37
Labroides Posted at 4-22 17:58
It is ok mate.. No need to apologise.. I'm sure the OP can try to change the ISO setting to Auto (if he had them set to manual) and see if that makes any difference to his white overexposed screen...
It was just a suggestion, not a cure for cancer...
2023-4-22
Labroides
Changing batteries or updating batteries can't cause what you've described.
Next time you see this, take a screenshot and it might give some clues to what you are dealing with.
2023-4-22
DJI Gamora
Hi, Stephen. We have sent you a PM, please check thank you.
2023-5-3
