Perdida total de señal (Mini 3)
3868 16 2023-4-24
Roberto Piko
Flight distance : 7750597 ft
Hola soy usuario de un Air 2s y un Mini 3, y uso el controlador RC, en la ultima version 1.9.9, estoy teniendo problemas con ambos drones, la del Air 2s ya la reporte y mande un video.
Con el Mini 3 tengo perdidas de señal total sobre los 170 metros y unos 30 de altura, siemre son vuelos en el campo y no hay ninguna torre de comunicacion cerca que interfiera con la señal. ¿Alguien mas tiene este problema?.
Adjunto Video: Mp4
2023-4-24
Sean-bumble-bee
Flight distance : 15997 ft
Why did you move the home point?
2023-4-24
Roberto Piko
Sean-bumble-bee Posted at 4-24 04:45
Yo estaba justo allí, y lo actulize porque lo tenía más cerca, y al recuperar la señal probé un poco, luego ya no tuve problemas, y pude realizar lo que quería grabar.
Saludos
2023-4-24
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. The main factors that affect the image transmission distance are firmware, signal transmitter power, attenuation, obstruction, and electromagnetic interference. Here are some recommendations that you may try:
1. Update or refresh the firmware of the drone and the remote controller through the DJI Assistant 2 (Consumer Drones Series).
2. Ensure that the remote controller's antennas are placed in an optimal position. See the picture below:
3.  Keep note of tree and house obstructions near the flying field. After flying for a period, note the obstruction near the horizontal line to ensure that there are no visible obstructions in the aircraft's direction. Take off from an area with no signal-blocking obstacles.
4. If there is significant signal interference in the area, change the environment or fly to a different location and check if the issue remains.
We will be waiting for your update. Thank you, and have a nice day.
2023-4-24
Roberto Piko
DJI Paladin Posted at 4-24 18:59
De todos los puntos, el único que necesito realizar es restablecer el firmware del Mini 3, el controlador estaba en la dirección correcta, si lo mira la señal del controlador estaba al 100%, siempre uso la aplicación UAV Forecast, y ese día KP estaba bajo, en esa zona no hay antenas que interfieran en La señal, seguramente sea problema del firmware, seguiré probando después de restablecer el firmware.
Saludos
2023-4-24
DJI Paladin
Roberto Piko Posted at 4-24 20:30
Saludos
Thank you for keeping us posted. Please try flying the aircraft to a different location for us to see if the issue persists. Please let us know after the tests. Thank you.
2023-4-26
Roberto Piko
DJI Paladin Posted at 4-26 04:53
Con la versión 1.10.0, ya llevo 2 días probando en varias ubicaciones y de momento no he tenido problema, hasta he estado debajo de un puente y orientando el mando al lado contrario, la señal perfecta, seguiré probando algún día más.  Pero espero que siga como asta ahora.
Saludos
2023-4-26
DJI Paladin
Roberto Piko Posted at 4-26 11:26
Saludos
Thank you for keeping us posted. Good news! we're glad that the signal improved and the issue seems to be fixed. Please don't hesitate to reach us if you have other inquiries. Thank you for your valued support.
2023-4-28
djiuser_WD7QfxvIuA8x
Panama
Después de actualizar la 1.12.3 mi Dji mini 3 pierde la señal a cada segundo no puedo ni volar a 20 metros se altura ni mucho menos de distancia no entiendo que es lo que pasa . Soy de Panamá. En ese estado mi drone no sirve para nada
2023-11-5
Panama
Yo tengo el mismo problema en el mini 3 igual que tu
2023-12-13
Roberto Piko
djiuser_WD7QfxvIuA8x Posted at 12-13 08:33
En mi caso con la última actualización la 1.12.5, no he tenido problemas, he echo varias pruebas en varios días a un maximo de 500m distancia y altitud 120m y la señal al máximo. Todo correcto.
Saludos
2023-12-27
E Esturillo
Estoy teniendo el mismo problema: En dos salidas, en zonas despejadas y sin obstáculos, pérdida completa de señal entre el Dron y el mando de 1-2 segundos. La primera vez pensé que se podía deber a una línea de alta tensión cercana, pero hoy he hecho una prueba específica en una zona totalmente despejada y libre de obstáculos y he perdido la señal a 30m de altura y 60m de distancia.
Dron: DJI Mini 3
Aplicación: 1.12.8
Firmware Dron: 01.00.0410
Remoto: DJI RC-N1
Firmware Remoto: 04.16.0500
1-27 03:26
Roberto Piko
E Esturillo Posted at 1-27 03:26
Dron: DJI Mini 3
Confirmo, el mismo problema perdida de señal total a una distancia cercana, y sin obstáculos.
en mi caso con el mando RC, y con todas las actualizaciones al día. (13/3/24)
3-13 01:49
djiuser_v2LvnlI5Rz1S
El otro día mi dron mini 3 pro perdió la señal con el mando y no volvió nunca más, me parece que DJI debería tener en cuenta que esto es un problema suyo , me ha tocado comprar otro completo por 800€
6-3 09:06
Roberto Piko
djiuser_v2LvnlI5Rz1S Posted at 6-3 09:06
Yo he tenido varias incidencias, la aplicación tiene varias opciones para cada caso, dependiendo siempre antes de volar asegurarte del que el regreso automático al lujar de despegue este activado, también esta la opción de ver en el mapa donde perdió el dron la señal y para acercarte al lujar para buscarlo, y si todavía le queda batería activar la señal acústica.
No se tu caso no lo especificas yo comento por ofrecer algo, y tampoco se si as realizado todo lo que arriba te expongo, yo perdí un Air 2S y no lo pude recuperar por que me era imposible acceder al lugar, lo demostré con datos a DJI y me hicieron un descuento. por mi parte el trato siempre a sido amable i cordial.
Saludos
6-15 02:51
He intentado ir donde las ultimas coordenadas pero es imposible acceder . Saludos.
6-17 03:00
DJI Natalia
djiuser_v2LvnlI5Rz1S Posted at 6-17 03:00
Hi there,
thank you for reaching out.
Please tell us the full details of the issue that you experienced with your DJI product, and we will surely provide you with an accurate resolution after we review the details.
Please keep us posted. Thank you.
6-17 03:36
