battery capacity was over a longer
591 8 2023-4-25
fpv-opa
Flight distance : 732 ft
Hi, I get allways the note "battery capacity was over a longer" in the goggles when I fly with the avata. What is the meaning of this note?
2023-4-25
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Can you please provide us a picture of the exact error message on the Goggles so we can provide you with an accurate resolution? Please keep us posted. Thank you.
2023-4-25
fpv-opa
DJI Paladin Posted at 4-25 21:09
Hi, DJI Paladin, here is the picture.
2023-4-26
SeehawerB
Flight distance : 5414203 ft
After installing a new firmware this warning came every some seconds, very annoying.
Here in englisch:
2023-4-26
frankymusik
Flight distance : 27904331 ft
SeehawerB Posted at 4-26 03:56
Here in englisch:
Finally understand what the OP wanted to convey...
2023-4-26
frankymusik
Did you try what SeehawerB detailed...?
2023-4-26
fpv-opa
frankymusik Posted at 4-26 22:11
Yes I have and then the message is gone
2023-4-27
frankymusik
fpv-opa Posted at 4-27 07:15
Thanks for feedback!
2023-4-27
DJI Paladin
fpv-opa Posted at 4-26 03:02
[view_image]
Thank you for the information provided. You may try the following troubleshooting steps as this might fix the issue. Please let us know if the issue persists. Thank you.
1. Please discharge the battery to less than 10% and let the battery sit for 1 hour, then fully charged and let it sit for 1 more hour, check if the prompt still exists;
2. Please insert this battery into the aircraft and refresh the aircraft firmware again via DJI Assistant 2;
2023-4-28
