HD Pilot
Flight distance : 5183799 ft
The Mini 3 Pro alternates green and red. it would be nice if the LEDs when illuminated inflight would stay solid Red on the left side and green on the right.
The Mavic 3 and Mavic 3 Classic flash red and green on the forward arms and alternate to the aft arms. Again, if the forward and rear arms had a steady lite LED , red on the left side arms and green on the right side arms.
The positioning lights on aircraft are red on the left, green on the right.
The logic is if you see green only, the aircraft is flying to the right of you.
If the lights are red, then the aircraft is flying to the left of you.
When you see red on the left and green on the right, the aircraft is moving away from you.
And when you see red on the right and green on the left, the aircraft is flying toward you. (a pilots adage - "Red Right, returning")
I hope this helps explain my thoughts.
Thank you |
