cameraguy UK
Flight distance : 196696 ft
APRIL 2023. I recently update the firmware to 02.00.72.87 on TX and RX. On the last 3 jobs i have used the mics on I have had bad signal breakup: a kind of 'bubbly' garbled effect that you would associate with poor data stream, and the signal strength meters are fluctuating a lot.
LOCATION 1 - Office, Central London. approx 10 feet line of sight. Fixed position PTC, TX on belt + lav mic.
LOCATION 2 - College building, Central London. approx 10-15 feet line of sight. Moving gimbal PTC, TX fixed directly to lapel (no lav mic).
LOCATION 3 - NEC Birmingham, Approx 10 feet line of sight. Fixed position interview, TX fixed directly to lapel (no lav mic)
The mics never used to break up at this short distance. On the last job I unded up using an older Hollyland Lark 150 (very similar form factor and carrier freq.) and it worked fine.
I also tested my old Rode Go (mk1) kit in the same location and it too was fine so I can only conclude that something is not right with my DJI Mic kit?
is there any way to roll-back the firmware?
