Why shoot D-Log-M?
4168 8 4-28 10:52
richparry
Flight distance : 1620148 ft
I've been shooting D-Log for years, now that the Mavic 3 supports D-Log-M, I wonder what advantage D-log-M has over D-log? Are there situations where shooting D-log-M is preferred?
Thanks,
Rich
4-28 10:52
ArcticPhoto
Norway
As far as I know there are no situations where D-Log M gives better quality than D-Log.
D-Log M is apparently a proprietary mode developed by DJI, with a non-standard colour space.
Professional filmmaker Philip Bloom says that D-Log M has lower dynamic range than proper D-Log. He does not like it, and he knows
more than most about editing video.
4-28 13:12
Mzp
Imho D-Log M  like HLG has adjustable ISO from 100 to 1600 in 100 increments, when D-Log has either 400 or 800 or 1600.
4-28 17:06
digibud
Flight distance : 6922510 ft
While it’s true that D-Log M has lower dynamic range that difference would be minimal to non-existent for most casual home users.  If you were sharing files with others using D-Log it would be important to use and if you had scenes with very high dynamic range then D-Log might be especially useful. D-Log M would, I think (no real direct experience...) have a reasonable range for most casual users.  I used to shoot DLog but now I only do when I have a challenging scene. DJI Normal mode might be an anathma to pros but it's really quite a decent take on color. I am just assuming the DLog M will really be quite good and am looking forward to it.
4-28 18:25
DJI Gamora
Hi, Rich. Thank you for reaching out. D-Log M allows the camera sensor to record enough dynamic range. As the photo has been processed, it leaves less room for grading in post-production compared with D-Log, but you can more easily color grade during post-processing.
While D-Log allows the camera sensor to pull as much dynamic information from the scene, get the maximum dynamic range compared with other color modes, and give you more flexibility in your post-production as the photo is not processed. But it will devote more time to post-processing as LUTs should be used to color grade D-Log footage before post-processing. For more details, refer to D-Log D-Gamut Whitepaper. (https://dl.djicdn.com/downloads/ ... amut_Whitepaper.pdf). Hope this helps.
4-28 18:54
digibud
DJI Gamora Posted at 4-28 18:54
While D-Log allows the camera sensor to pull as much dynamic information from the scene, get the maximum dynamic range compared with other color modes, and give you more flexibility in your post-production as the photo is not processed. But it will devote more time to post-processing as LUTs should be used to color grade D-Log footage before post-processing. For more details, refer to D-Log D-Gamut Whitepaper.   (https://dl.djicdn.com/downloads/zenmuse+x7/20171010/D-Log_D-Gamut_Whitepaper.pdf). Hope this helps.
What he said
4-28 19:53
Burt37
Flight distance : 4009 ft
If you watch this video you will see the difference...
4-28 22:05
DJI Gamora
Hi, digibud. Is there anything we can help you with? Please let us know. Thank you.
4-30 07:13
Grimtheviking
Flight distance : 11213711 ft
Burt37 Posted at 4-28 22:05
https://youtu.be/vRKiCC01r9U
Well explained, thanks for sharing.
4-30 10:40
