dji assistant 2 - server exception(2-0) error for RC-N1
2229 13 2023-4-30
wolverine99
Flight distance : 10157 ft
India
I tried updating my rc firmware in dji fly app which showed server error. i then tried with dji assistant(consumer version) for firmware update. It shows server exception (2-0) error.
kindly look into this and help me solve this issue.
2023-4-30
wolverine99
India
2023-4-30
DJI Wanda
Hello, there. How about uninstall and reinstall the DJI Assistant 2? Does it work?
2023-4-30
wolverine99
India
It doesn’t work
2023-4-30
wolverine99
India
I need my remote pilot station number to register my drone for travel purpose. My RPS number is not available even in dji fly app. Kindly help me. I tried all possible ways.
2023-4-30
Berk Karşı
Turkey
I'm having the same problem. Has anyone found a fix?
2023-5-7
wolverine99
India
Berk Karşı Posted at 5-7 03:08
[view_image]
All you have to do is
1. Disconnect the drone and power it off
2. Switch on your RC-N1 and connect it with your phone
3. Go to connection guide in dji fly app
4. Click the model of your drone
It will pop up like “ firmware version of RC outdated”
And will ask for an update
Select it
You have to update it using the options then.
Cheerios
2023-5-9
DJI Paladin
Flight distance : 318 ft
[view_image]
Sorry for the late response. We're sorry for this unpleasant experience. Please the use App to update the firmware for a try (Please click the "connection guide" first and then choose the corresponding aircraft model, and then the App will prompt an RC firmware update note), after app updated succesfully, and then connect to DJI Assistant 2 software again. If the app still not prompt RC update information, please let us know. Hope this helps. Thank you.
2023-5-20
jwhite1089
wolverine99 Posted at 5-9 03:53
I created a DJI Forum account just to confirm this answer for anyone else searching tirelessly for it in the future...
This is the only thing that worked for me.
I am using:
- iPhone 14 Pro Max
- Macbook Pro M1 Pro
- DJI Mini 2
- RC-N1
I first noticed the issue when trying to bind my devices. I tried to update via Settings in the DJI Fly app on my iPhone, and also tried using DJI Assistant 2 on my Macbook. Both times I got server errors, and upon refreshing endlessly I would get nothing.
I finally found this answer, and it worked, with one caveat (for me anyways) - After entering the connection guide and selecting DJI Mini 2 I had to wait for almost a minute before the update finally popped up. Previously I did not wait that long and thought it wasn't working.
I have read through at least ten posts on this forum about this specific issue, and I've got to say, I am extremely disappointed in what I've seen from DJI support. They've replied and asked basic questions about rebooting, unplugging, trying via the app or via DJI Assistant 2, etc. and every time that person replied saying they already tried that and it did not work, etc. and I never once saw a follow-up reply from DJI except maybe two saying they had sent a DM...
DJI - This is an obvious issue on your side - Own it, make a post about why it's happening, how to work around it, and fix it so that it doesn't happen to others in the future. These devices are not cheap, this is clearly a widespread issue (and has been for at least two months now), and this level of support is entirely unacceptable.
EDIT: I see the (late) response from DJI with the correct answer above; my main point is that the solution to this problem should not be found by asking a question on the forum. The issue should be identified and fixed, but if that can't happen for whatever reason there should be a release note or an easily discoverable article outlining the problem and the workaround note above. I work for a major tech company; when our customers can't update, it's a major issue. Even if they're using slightly older hardware.
2023-5-27
denlim
Flight distance : 8960 ft
This solution really works.. my problem resolve. Drone and RC now updated and activated.
2023-6-13
Rob D
Finally! Direct and to the point. DJI needs to make this clear to users via a pop-up or just fix the issue
2023-7-10
DJI Tony
Rob D Posted at 7-10 18:59
Hi, Rob D. We would like to take that as a suggestion. Rest assured this will be referred to our developers. Thanks for the support.
2023-7-10
Dr.Strangelove
Flight distance : 39 ft
jwhite1089 Posted at 5-27 06:28
You my friend are a Rock Star. Thank you SOOOO much. DJI really dropped the ball (such a large company). I think many people can cause harm by getting frustrated and messing about with firmware. Again, thanks!!!
Genius
2023-8-13
rgeorge971
THANK. YOU.
2023-12-9
