Ronin RS 3 Mini - Canon EOS R Camera Connect Cable Error
2991 4 2023-4-30
CSaf18
I recently purchased the DJI Ronin RS 3 Mini online, about 2 weeks ago. Since receiving it, I have not been able to successfully use the Ronin in-app track and capture features with my Canon EOS R + Kit Lens RF 24-105mm lens. In the Ronin app, under "Status", the "Checklist" tab, it shows bluetooth connectivity to the device but an error for the Camera Control Cable
  • Ronin app is showing a connection to the RS 3 Mini at the top; I am able to use the virtual joystick to control pitch, tilt and roll
  • The DJI Ronin RS 3 updated its firmware on my first use to 01.02.00.00
  • The DJI Ronin App is v1.6.6(1060620) and not showing any new updates in the Apple app store
  • My Canon EOS R has the most up-to-date firmware from Canon; v1.8.0
  • I'm using the USB-C to USB-C included DJI camera connection cable
  • DJI support page indicates that the Canon EOS R is compatible with specifically the MCC-C included cable; I've tried additional USB-C cables with the same result
  • I've powercycled both the RS 3 unit, the camera, and checked all connections while plugging them in at various times during start-up
Nothing seems to register the connection at all - I can still return and replace the Ronin unit in case it is faulty but has anyone had a similar issue and resolved it with another method?
Thanks
2023-4-30
J Loo
Singapore
Hi there, I'm experiencing the same issue as well and no luck to resolve this.
Support can kindly assist?
2023-6-30
Videografic
Flight distance : 4853665 ft
Any solution in this case provided by DJI?
2023-7-21
Kune
Flight distance : 2773465 ft
Same here. The first time I tried it worked, but now don't. Not sure when it happened, maybe after updating the firmware I guess.
-- JUST WANT TO CONFIRM IT IS WORKING AGAIN AFTER FORCING THE FIRMWARE UPDATE--
2023-8-1
Michael-UNCP
Using the included USB-C cable with the Ronin RS3-pro and the Canon R3 works sometimes and not others. Same cable.
2024-8-21
