17-28 remote zooming
3005 12 2023-4-30
fans097a2016
Is their a way to zoom the 17-28 lens when using the remote monitor with grips ?
2023-4-30
DJI Wanda
Hello, there. May we know if you want to know the detailed steps when using DJI Ronin 4D with an electronically tunable zoom lens, turn the dial of the right-hand grip to adjust the focus? See below:
1. Press the HOME button to enter the menu, select “User Settings”, and change “Press & Hold Right Hand Grip Trigger” to “Zoom”. (Note: It also supports changing “Press & Hold Right Hand Grip Trigger” into “Z-Axis Lock”.) At this time, press and hold the trigger of the right hand grip while rotate the dial to control the focus.
2. Press the Mode button on the right hand grip to set the dial for zoom control. When the lens focal length value turns into yellow, it indicates that the mapping is successful. At this time, turn the dial on the right handle grip to control the focus of the lens.
Note: It is required to update the firmware to v01.04.0200 or above to use these functions.
2023-5-1
fans097a2016
DJI Wanda Posted at 5-1 00:01
How do I zoom using the high bright monitor
2023-5-1
DJI Wanda
fans097a2016 Posted at 5-1 16:56
Do you want to zoom without hand grips?
2023-5-2
fans097a2016
DJI Wanda Posted at 5-2 07:03
No I want to zoom with the grips on the high bright monitor.
2023-5-2
DJI Wanda
fans097a2016 Posted at 5-2 07:36
It requires you to switch the cursor to focal length parameters first and then you can use the hand grips to control zooming.
Method:
1. Enter the high-bright main monitor’s menu, and go to “Settings” - “Lens” - “Motor” - “Focus Motor Initialize” to complete the zoom travel calibration. No manual calibration or automatic calibration is required for the lens.
2. Go back to the home page and use the Mode button on the right hand grip to move the cursor to the lens focal length in the bottom right corner on the screen. This can control the zooming through the dial of the right hand grip
Note: Updating the DJI Ronin 4D firmware to v01.04.0100 is required.
2023-5-5
fans097a2016
MY FIRMWARE IS UPDATED
THIS IS FOR THE HIGH BRIGHT WIRELESS MONITOR WITH GRIPS
MODE BUTTON DOESNT WORK
ZOOM DOESNT WORK
WHAT YOUR SAYING MAKES NO SENSE AT ALL
2023-5-5
fans6a388460
fans097a2016 Posted at 5-5 04:45
Is there an answer yet?
2023-7-27
fansd8781149
Flight distance : 31145 ft
no way. DJI forgot to do it with programmers. i need operate zoom with monitor but i have too walk to camera and do it every time. sucks
2023-11-28
826 Raw
Flight distance : 414226 ft
I have noticed the same and added it into the forum
2023-12-7
fansd8781149
hey. i am waiting answer.
2-15 12:51
826 Raw
fansd8781149 Posted at 2-15 12:51
I would also like to hear back regarding this thread, it would be invaluable to be able to focus lenses via the HB Monitor. Both for the I3 (then you guys launch the awaited lens) and the Ronin 4D,
2-17 01:00
fansd8781149
?????????????????????? waiting. need zoom lense by hight bright monitor
4-22 21:09
