Camera calibration error
896 1 2023-4-30
djiuser_hJIIpxjqorFO
I am getting this error since i switched camera/gimble from another drone. i cannot find anything on this in any thread. i tried refreshing to the firmware on assistant 2 it still persists. i also calibribrated the vision and gimble but there is no option for camera. i can record and gimble works fine but the error is there for a reason. how do i calibrate the camera?
error
error
2023-4-30
DJI Gamora
Hi, djiuser_hJIIpxjqorFO. Thank you for reaching out. Please try to check whether the protective cover of the gimbal is removed, and check whether there is any foreign object on the gimbal that causes the gimbal to be stuck. If there is, please remove it. You mentioned that you already tried refreshing the firmware, may we know if you performed it with the drone only or with the goggles as well?
2023-4-30
