Inspire 2 Apple ProRes Light Flicker
1105 5 2023-5-1
fans93af3118
When filming with my Inspire 2 in Apple ProRes 422, i will get this flicker that i can't quite figure out. This has been going on for months now and has progressively gotten worse. The h.264 file on the sd car does not have the flicker. So i know the issue has to have something to do with the ProRes encoding. When filming in cinema dng, I do not have the issue either. So, again I don't believe the issue has anything to do with my actual SSD cad. I attached a a youtube video that shows the problem. It can be seen at the 10 and 15 second mark. My ISO is fixed, so nothing is changing on my camera settings during flight. It will happen when my drone is stationary and when I'm flying. It will also happen when My gimbal is stationary and when my gimbal is moving so I don't think it's a gimbal issue. It will happen when shooting into the sun and when I'm shooting away from the sun so i don't think it has anything to do with the exposure of my composition. Anyways, let me know if any of you have any idea on what this may be:
https://youtu.be/uHyRhIg2EnQ
2023-5-1
ScooterC5
Flight distance : 435052 ft
Recommend providing some more info like camera, lens, and settings.
2023-5-1
fans93af3118
ScooterC5 Posted at 5-1 20:27
Thanks.  I was using the zenmuse x5s.  The particular lens on my camera body is an olympus 25mm lens.  The setting for this clip were iso 200.  1/60 shutter speed.  Aperture was at 4.0
I'm not positive if i have the same issue using my standard dji lens.  I don't hardly ever use that lens.  Although i could trouble shoot that tomorrow.  I have the flicker at all apertures and at all shutter speeds.
2023-5-1
ScooterC5
fans93af3118 Posted at 5-1 20:48
My best guess is that it's the camera. Worse case you send in to DJI for a repair estimate after explaining the issue.
2023-5-5
fans93af3118
ScooterC5 Posted at 5-5 09:08
Thanks so much for the response! Do you think it could be the camera if the h.264 and the cinema dng files come out perfectly? It’s only the Apple pro-res file that gets corrupted.
2023-5-8
djiuser_TD2nVaU2sYAE
How did you go with a solution for this? I just experienced the exact same issue (prores 422 HQ) and wanted to figure it out!
4-13 02:15
