LV_Forestry Posted at 5-3 05:15
How much is the MTOM of a privately built drone ? You confuse C label and privatly build or purchase before 01/01/2023. Ask your CAA and you'll see.
Stop reinventing the law. Below 250g home made or buy before 01/01/2024 it falls into this category. There is nothing else to add.
I'm not re-inventing the law, I'm understanding it in a different way than you do. And my understanding is based on what has been discussed on local forums by experts and lawyers (including a responsile from EASA).
The Article 20 of the Regulation is clear:
"UAS types within the meaning of Decision No 768/2008/EC of the European Parliament and of the Council85, which do not comply with Delegated Regulation (EU) 2019/945 and which are not privately‑built are allowed to continue to be operated under the following conditions, when they have been placed on the market before 1 January 2024:
(a) in subcategory A1 as defined in Part A of the Annex, provided that the unmanned aircraft has a maximum take-off mass of less than 250 g, including its payload; (b) in subcategory A3 as defined in Part A of the Annex, provided that the unmanned aircraft has a maximum take-off mass of less than 25 kg, including its fuel and payload."
It refers to the MTOM and the MTOM is a specification declared by the manufacturer, not measured by the user. I know there are pending requests to modify this Article, in order to make it more friendly for the small drones. But if the modification won't approved, the Mini 2 will be outside the A1 subcathegory.
But If you're comfortable with your interpretation, be happy and have good flights.
BTW the MTOM for my privately built drone is the one I want to declare (after measuring it, of course).
