"NO SIGNAL" message for lightbridge
edwardcollinson
Hi,
For some reason when I started my Phantom 3 Pro today, I saw the "NO SIGNAL" message pop up.
It claims that Lightbridge is connected, I get Histograms and it does record the footage.
However I only get a black screen come through on my iPhone 5s.
I am running the latest Firmware (1.3.20) and the latest version of Dji Go.
So any ideas?
Thanks for reading
- Ed
2015-8-24
jimcloud74
Flight distance : 1298317 ft
Try a new cable.
2015-8-24
edwardcollinson
I've tried that, to no avail.
I even tried using a completely different device on a different platform only to get the same results :/
2015-8-24
jimcloud74
edwardcollinson Posted at 2015-8-25 05:11
I even tried using a completely different device on a different plat ...
Ok, check the camera plugs on the gimbla plate. Try to lift them and push them back in. Sounds like the camera is having connectivity issues.
2015-8-24
L8again
Are lots of threads on this problem. Search around a bit.
2015-8-24
Phantom_Film
Flight distance : 1609482 ft
Greece
http://forum.dji.com/forum.php?m ... mp;extra=#pid197728
There is a big possibility that the failure of the bird's camera to upgrade might be causing these black outs and NO SIGNAL messages.
If you can find in your sd card the hidden folder named MISC and LOG inside there you will find a txt. If you can send it to dji maybe they tell you what may be the problem...
A member told us here that dji asked him to send over the p3p for camera service !
I hope its something simple for you.  I also keep having these NO SIGNAL and did 1-2 things that just made it a little better... the 32 channels hack, and restart sometimes the app while in the air , when i have no video on my ipad...
2015-8-24
edwardcollinson
I can confirm that backdating my bird managed to get the view again by backdating to 1.2.6, and it does seem to work. No issues as of yet (Except it complaining about out of date firmware),
So that's my temporary fix for now, I'll keep you all updated what happens when I try upgrade again!
2015-8-26
SpunOne69
If the P3P is technically using "Lightbridge" to transmit the video...how come the actual "lightbridge" app wont work with the P3P??  Just wondering....
2015-8-26
edwardcollinson
I haven't a clue myself, I assume it only works with the older version of Lightbridge.
2015-8-28
