Change center of rotation to reduce parallax stitching errors
728 5 2023-5-3
djiuser_9CZqZ7Oy2K47
Flight distance : 2242956 ft
Cyprus
Hi.
wouldn't be possible to change the centre of rotation during pano shots and 360 shots to the camera sensor from the middle of the drone?
this will reduce parallax stiching errors to a minimum
theoretically would be just like rotating around poi but the poi is the camera sensor
software wise i don't believe is very hard to do, the only issue would be if the drone is able to perform such manoeuvring for close poi
2023-5-3
DJI Paladin
Flight distance : 318 ft
Thank you for your feedback. We really appreciate the time and effort you have invested in providing this suggestion to us. Your feedback will be definitely cascaded to the concerned team for further review. Thank you for your understanding and support.
2023-5-3
Sean-bumble-bee
Flight distance : 15997 ft
Have you tried that with a normal camera on a tripod?
It's quite tricky and involves testing and adjusting the centre of rotation by cm or mm to get it correct. I very much doubt such accuracy is possible with an airborne camera.
2023-5-5
Cyprus
Sean-bumble-bee Posted at 5-5 03:19
Well, i said reduce the effect not eliminate it alltogheter. It won t be perfect but will be better than we have now when the rotating center is the mid of the drone. If it s not a big deal to implement it why not have even slightly better results? As i ve started taking lots of 360, 180 and wide angles shots recently, anything that gives better results in stiching is welcome
2023-5-5
Sean-bumble-bee
My point was, if, with a tripod mounted camera, a few cm or mm of incorrect positioning can introduce parallex error then, it would be impossible to maintain such positioning accuracy with an airborne drone that is subject to wind even if the drone was low enough for VPS to be responsible for position holding.
Remember GPS error is measured in ft or metres not cm or mm. Yes, when considering ONLY the drone, DJI could possibly program the drone to rotate about the nodal point but when the whole drone can be shifted by ft or m ........
2023-5-5
Cyprus
Sean-bumble-bee Posted at 5-5 07:02
with the rotation centre in the mid the drone is still susceptible to gps drag, wind etc/. they will just introduce a rotation centre offset to the camera and the drone will use the same measurements from gps as before with a constant offset. if the drone had positioning errors before will have the same errors now as the offset is constant. the distance from the camera to the mid won't change. this offset would be applied automatically when the drone is taking pics in pano mode
2023-5-5
