Dji mini 2 camera
1627 7 2023-5-3
fans3a8a20db
Flight distance : 5469 ft
Hello, my dji mini 2 only sends back 720p photos too my phone even though the quality i chose was higher can somebody explain why this happens adn also how do i get it too take 4k 30 fps videos/photos on my phone or another way thank you.
2023-5-3
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please confirm if you are referring to videos when you mentioned the 720p? Please note that the video resolution of the DJI Mini 2 is as follows:
4K: 3840×2160 @ 24/25/30fps
2.7K: 2720×1530 @ 24/25/30/48/50/60fps
FHD: 1920×1080 @ 24/25/30/48/50/60fps
Lastly, you may export your high-quality videos (4k/30 fps) by removing the SD card on the unit and inserting it into your computer. Thank you.
2023-5-3
DAFlys
The high quality images are on the SD card inside the drone.
2023-5-4
djiuser_E61FCQDaYZBl
Flight distance : 232720 ft
make sure you changed your camera settings so it is taking pictures at the quality you want
2023-5-4
fans3a8a20db
DJI Paladin Posted at 5-3 22:51
I'm referring too videos and photos both go straight too 720p even though I chose a higher quality
2023-5-4
fans3a8a20db Posted at 5-4 14:02
Is that happening in the app like what is being directly received from the drone? or the SD card on the drone?
2023-5-4
DJI Paladin
Can you please check the original file that was saved on the SD card? Can you please upload sample files via Google Drive and send the link here so we can check? Please keep us posted. Thank you.
2023-5-4
djiuser_mLgH2Z0MwsmQ
Chile
debes revisar la tarjeta sd
2023-5-6
