Remote control as a battery pack charger
250 2 2023-5-8
Bob V.
Flight distance : 80833 ft
Czechia
Hi, can I use my remote control as a battery pack charger to charge my drone?
If I put USB-C/USB-C short cable (normally used for phone connection) to connect charging side (closer to me) of a remote control AND the drone - the drone will charge!
But after a few minutes the charger start beeping and turnd-off automatically; you have to "cancel" beeping every few minutes so that you are able to charge the drone (continue charging...).
Can I skip this or is there any programming or work around?
Thanks, Bob.
2023-5-8
DJI Gamora
Hi, Bob. Thank you for reaching out. Do you have an RC-N1 remote? If yes, regretfully, you cannot use it to charge the drone. You may charge the aircraft via a power bank through the battery charging hub or the aircraft. However, we recommend using an official charger. Thank you for your kind understanding.
2023-5-10
Shawgod
Flight distance : 5173104 ft
What is the reason that you want to do this?
2023-5-10
