altimeter
2160 8 2023-5-9
AJBC
Portugal
Does anyone know what type of altimeter the Mini 3 Pro has? GPS or barometric? The manual doesn't say what it is.
2023-5-9
Sean-bumble-bee
Flight distance : 15997 ft
Barometer, otherwise there wouldn't be height restrictions when GPS is weak. Page 61 of the manual.
https://dl.djicdn.com/downloads/ ... _User_Manual_EN.pdf
2023-5-9
JJB*
Flight distance : 12260774 ft
Hi,
Barometric sensor.
Baro height is zero`d at take-off, this reference height is used for the whole flight and reset back to zero at land-on (drone on the ground)
For low height the bottom IR sensor measures the actual height drone>surface below.
2023-5-9
frankymusik
Flight distance : 27841053 ft
JJB* Posted at 5-9 09:31
Hi,
Barometric sensor.
Once again: absolutely perfect explanation...
2023-5-9
DJI Gamora
Hi, AJBC. Thank you for reaching out. Mini 3 Pro uses a barometer and it also has a downward infrared sensing system, which is also used for flight altitude measuring.
2023-5-10
AJBC
Portugal
Thanks, but I didn't see that explicit in the manual. I need to register in my country and they want to know the altimeter of my Mini 3 Pro.
2023-5-11
AJBC
Portugal
Does the mini 3 Pro have a geofencing system?
2023-5-11
Sean-bumble-bee
Alternatively switch everything on, put the drone in a box in a plastic bag box and suck the air out of the bag or blow air into the bag and watch the indicated height change. For memory ''been there done that'' but don't remember what height changes I achieved.
2023-5-11
DJI Gamora
AJBC Posted at 5-11 01:02
Hi, AJBC. The altitude used by consumer products is measured by the barometer which is easily affected by many factors such as weather and may have a deviation, so there is no documentation about it and the height is only for reference. Just to add, yes, Mini 3 Pro has a geofencing system. Please refer to this link: (https://fly-safe.dji.com/nfz/nfz-qa).
2023-5-12
