DJI RS3 mini rolling problem
6314 18 2023-5-9
McDicky604
Not sure what happen , everything balance but once i turn on the gimbal this is what happen. I have attacted the video. Please help.
https://youtube.com/shorts/CnXMZaX6DTA
2023-5-9
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to re-upload the video as the link is not working on our end? You may upload the video via Google Drive and send the link here so we can check. Please keep us posted. Thank you.
2023-5-10
McDicky604
Thanks for the reply, The unit already shipped back to DJI.
2023-5-10
rodolfovaliense
Flight distance : 176604 ft
Brazil
I have the same problem!
2023-5-15
rodolfovaliense
Brazil
I'm having problems, I'm getting error code 1009 on my RS3 mini, it's perfectly balanced
2023-5-16
DJI Paladin
rodolfovaliense Posted at 5-16 05:59
Hi there. Thank you for reaching out and we're sorry for the trouble. Kindly please follow the troubleshooting steps below and see if the issue persists.
1. Ensure that the camera load has already been mounted properly.
2. Ensure that the gimbal has been balanced.
3. Ensure that the gimbal Auto Check does not have interference.
4. Ensure that all axis locks are unlocked.
If you still experience the same issue, please record a short video showing the issue with the error message so we can check it. Please keep us posted. Thank you.
2023-5-28
DJI Paladin
McDicky604 Posted at 5-10 21:30
You're welcome. We're sorry for this unpleasant experience. Rest assured that we will conduct a thorough test on your unit once it arrives at our facility. Our team will provide you with updates via email. Please don't hesitate to reach us if you have other inquiries. Thank you for your valued support.
2023-5-28
fansba027a32
Flight distance : 456 ft
Japan
I'm currently traveling and my DJI rs3 mini having the exact same problem now. Quite disappointed.
2023-5-31
rodolfovaliense
Brazil
DJI Paladin Posted at 5-28 00:01
I would like help so that I can send my product from Brazil to DJI
2023-6-9
DJI Paladin
rodolfovaliense Posted at 6-9 12:30
Hi there. Thank you for reaching out. We're sorry that you are having issues with your unit. If your unit is within the warranty period, kindly please contact our support team at https://www.dji.com/support to open a ticket. Should you have other inquiries, please don't hesitate to reach us. Thank you for your understanding and support.
2023-6-11
onymar
Flight distance : 564400 ft
Also getting error 1009 along with 1008 and 1005.
This appears to be a common problem with the rs3 mini, hopefully DJI  will actual find out what is causing this annoying error as it is a complete pain to have to send back an item that has a common fault.
Is this a potential design fault?
2023-7-26
JomAnza
Is there an update on how to fix this? I have the same problem. Error Code 1009. This happened to me in a middle of a wedding shoot and caused me to miss a very important shot.
2023-8-2
djiuser_pPxu4nVVGK71
Bangladesh
DJI Paladin Posted at 2023-5-10 18:47
Hi there,
I just Bought DJI rs3 mini last friday, i haven’t use it till now. But when i testing everything ok or not?! I am also facing the same ..., 360d roll not working. Its says the same thing like others. I am balancing the gimbal very well before turning on and Calibrating.
So please give me the solution.. I am worried about it.
3-4 10:29
DJI Paladin
djiuser_pPxu4nVVGK71 Posted at 3-4 10:29
Hi there,
Hi there. We do apologize for the inconvenience caused. Can you please upload a short video showing the issue? You may upload the video via Google Drive or YouTube so we can check it. Please keep us posted.
3-6 22:59
djiuser_isyV1mDBbtWl
Philippines
Hi, it is normal?  When i use my rs3 mini i heard a weird sound,  like (grshhhh) donuu what it is, the gimbal is balance but when i use to take a video it turn to unbalance and i heard a weird sound. How can i fix it?
3-12 06:59
DJI Natalia
djiuser_isyV1mDBbtWl Posted at 3-12 06:59
Hi there! Could you please clarify if your RS3 Mini makes noise during shooting or while performing auto-calibration? If possible, could you kindly record a video of the issue and upload it to Drive, then share the link with me? I can forward this to our engineers and help resolve the issue for you.
Thank you
3-13 00:40
djiuser_XaftO8AHaBeK
Hi there
Rs 3 mini Gimbal is perfectly balanced but once turned on the roll access is showing as off and won't allow me to re-calibrate the gimbal.
Meant I couldn't use it on a shoot I had planned for. This needs to be a reliable product.
3-26 01:26
your forum wont allow me to post video of the issue
3-26 02:35
3-26 03:45
