Mini SE long replacement cable
407 5 2023-5-11
john pro
Greece
Hi all,
I want a longer  ~(1M/3ft) cable to connect my controller (MR1SD25 - I'm in Europe) to my samsung Galaxy phone.
I tried an extension and it didin't work and I'd like to avoid using an adapter.
I believe I need a USB OTG suppported cable and my question is which of the two devices acts as the host, the controller or the phone?
From what I understand the host needs to be plugged in one of the specific sides of the cable so since controller is micro usb and phone is type c
do I need a microUsb->typeC or a typeC->microUsb cable?
I didn't find the above info in the manual.
Thank you!
2023-5-11
DJI Susan
Hi there, you were referring to which side the OTG cable needs to be connected to, right? If yes, the OTG cable will be connecting to the controller side.
Kindly note that the micro USB plug that is connected to the controller is not a standard/popular one in the market, you may refer to the connection cable that comes with the controller, the side that plugs into the controller is not like the regular micro USB in the market. You may try to go to the electronic devices store nearby, and test the connection first before you buy. Thank you for your understanding.
2023-5-12
john pro
Greece
Thank you for your response.
Can you recommend and specific cable or where to order online?
As far as I know DJI doesn't sell such long cables.
2023-5-13
DJI Diana
Flight distance : 2408 ft
john pro Posted at 5-13 05:19
Hi there. Correct, we do not have this part available for sale. As previously mentioned, we suggest going to a nearby electronic devices store and try looking, to test the connection before purchasing one. Apologies, we can't provide any recommended stores/online stores. Thank you for your understanding.
2023-5-13
john pro
Greece
ok , thank you I'll go to a local store.
Best regards
2023-5-13
DJI Wanda
john pro Posted at 5-13 09:02
Best regards
Thank you for your reply. If you have any questions, please feel free to talk.
2023-5-13
