DJI Tony
Hi, olivermast. Thanks for reaching out, and apologies for any inconvenience this may have caused. DAFlys is right. You need to manually link it if you need to change drones. Moreover, given that the DJI RC Pro is compatible with both drones, the precondition is that the correct remote controller firmware needs to be selected. If the remote controller firmware is incompatible with the aircraft, the linking will fail. Hence, the prompt to update every time you switch aircraft. We will record your feedback and relay them to the designated team. We appreciate your understanding. |
