djiuser_zKR5HFX3a2EC
![](https://forum44.djicdn.com/data/attachment/common/c5/common_13_usergroup_icon.png) lvl.4
Flight distance : 474537 ft
DJI Gamora Posted at 5-15 20:13
Hi, djiuser_zKR5HFX3a2EC. Thank you for reaching out. 4 lights do not refer that it is fully charged, please fully charge it and check the battery percentage in RC then test it again. Also, the low-temperature environment will lead to fast power consumption as well, please try to avoid the low-temperature environment as much as possible. If the RC can still last for only one hour from fully charged to run out after the test, please send it back to us. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at (https://www.dji.com/support). Also, the Mavic 3's max flight time was measured in a controlled test environment. Specific test conditions are as follows: No wind, at sea level, the constant flight speed of 32.4 kph, APAS off, AirSense off, camera parameters set to 1080p/24fps, video mode off, and flying from 100% battery to 0% battery. Results may vary depending on the environment, usage scenario, and firmware version. Your kind understanding is appreciated and thank you for your continued support.
I was testing using the 4 green lights. I thought 4 is 100%, 3 is 75%, 2 is 50%, 1 is 25%. After 30 mins i am getting 2 green lights.
I recharged the rc controller until the lights goes off. I checked on the controller and is 100%. I leave it on indoor play back videos on the controller. Wifi and Bluetooth off. Brightness is 3/4. I timed it. 9:23am.....at 11:22am the controller 0% and automatically shut down. So basically from 100% down to 0% is 2 hours. I was expecting at least 3 hours given the advertised 4 hours. Anyone have the rc controller can verify how long they are getting before they need to charge it. If 2 hours is from 100% to 0%, then realistic fly time is really only 1 hour and 30 minutes. |
