Qu for DJI, unwanted extreme climbs & "Anytime" CSC ?
861 12 2023-5-15
Sean-bumble-bee
Flight distance : 15997 ft
There seems to have been a spate of un-commanded climbs in the past month or so, from memory at least one has broken the height limit set by the pilot. One climbed to near 500m.
My question is. If during the climb the "emergency motor stop" option was changed/set to "Anytime" would the CSC have stopped the motors with the drone in mid air?
2023-5-15
DJI Tony
Hi, Captain. Thanks for reaching out. Yes, if it's set to "Anytime," the motors can be stopped mid-flight when the CSC is performed.
We hope this clarifies your concern.
2023-5-16
Sean-bumble-bee
DJI Tony Posted at 5-16 00:05
[view_image]
Thanks Tony but it doesn't really clarify the matter.
I know what the manual suggests should happen and have experimented with that and a drone in normal flight.
But I am asking if, in real life, where the drone is climbing out of control i.e. climbing, and perhaps climbing rapidly, whilst the throttle is fully closed, i.e. seemingly ignoring joystick input, will an "Anytime" CSC stop the motors with the drone in mid air and in the midst of such an uncommanded climb?
I think it should but "think" is not really an ideal position to be in in those circumstances.
Perhaps this is a question that could be forwarded to your engineers and coders.
2023-5-16
DJI Tony
Sean-bumble-bee Posted at 5-16 01:43
We understand. We'll have it forwarded for confirmation. We'll keep you posted, Captain.
2023-5-16
Sean-bumble-bee
Thanks Tony.
2023-5-16
DJI Tony
Hi there. Apologies for the delayed response. As confirmed by our engineers, this function has a condition.  If the RC cannot control the aircraft normally during these scenarios, this function will not work.
2023-5-22
Sean-bumble-bee
DJI Tony Posted at 5-22 05:12
Thanks for the reply Tony.
However my response to that news is ........ Oh that is not good !
2023-5-22
Ranjan
India
Will pressing the Pause button on the controller work & pause the fight in this case?
2023-5-22
Sean-bumble-bee
Thinking about that it might have been that the drone was not ignoring all the commands issued by the controller. I do not remember if the pilots had horizontal control, rather, that some fault was causing the drone's control system to override the throttle input.
For discussion's sake, can you please ask those engineers what would be the situation if the drone was complying with the rudder, aileron and elevator inputs but that the drone was apparently ignoring/overriding  the throttle input and climbing due to, perhaps, a malfunctioning barometer.
2023-5-22
Bashy
Flight distance : 2354357 ft
Sean-bumble-bee Posted at 5-22 08:59
I think your question may have been misunderstood as you were not referring to an RC disconnect, only that the drone was out of control in a way that it was Ascending with no input, under that scenario, i would say that CSC (Anytime) would or should work.
2023-5-22
Sean-bumble-bee
Bashy Posted at 5-22 18:37
That's my hope too. It's also the reason for post #10, which I hope makes things clearer for DJI's engineers.
2023-5-22
DJI Tony
We understand your input. Let us relay this inquiry for further confirmation. Thank you.
2023-5-23
Sean-bumble-bee
DJI Tony Posted at 5-23 04:03
Thank you Tony.
2023-5-23
