connection to Headset Pico4
3350 6 2023-5-16
whynotWi
Hello,
has anyone already connected the drone to the headset Pico 4 ?
I could download the DJI-software and install it. But when i tried to connect the drone to my headset the app stucks in the starting screen.
I've tried several options and several wires (to make sure there is no hardware problem). But nothing helped. When i connected the drone to my mobile it works as desired. Hence i assume there is something missing on the headset ? Of course it has no GPS, but is that required, so no connection between both devices is possible ?
Help is appreciated.
regards
Stefan
2023-5-16
DJI Wanda
Hello, there. Sorry for the inconvenience. Consumer drones do not support VR function, and therefore do not support VR goggles.
2023-5-16
djiuser_uuLT09vPzH1k
This topic is interesting, let me explain the situation.
They work perfectly, I have a DJI Mini 2 and the pico 4 and it can be piloted on a Giant Screen, without being immersive and they worked until January 2023.
There were 2 updates around those dates from both PICO and DJI, and I don't know which of the 2 blocked the input signal, and now it only records the input from the drone controller as Battery Charge.
I made several claims, they only suggested installing previous versions, they do not give explanations.
All the best.
2023-6-10
DJI Wanda
djiuser_uuLT09vPzH1k Posted at 6-10 07:25
Hello, there. We are sorry that the headset is not supported and we did not test the compatibility before. We can not guarantee the performance as well. If you tested that the previous firmware can work, then the only method to reverse back to the previous firmware.
2023-6-10
Serpens_Alatus
Greetings.
Very interesting topic. How can i install die DJI App on the Pico and connect? Is there a howto?
Thank you
Regards
Serpens
2023-7-22
DJI Gamora
Serpens_Alatus Posted at 7-22 08:43
Greetings.
Hi, Serpens. Do you have a consumer drone? If yes, regretfully, consumer drones do not support VR function, and therefore do not support VR goggles just like Pico.
2023-7-23
Christian_MUC
Flight distance : 1023579 ft
djiuser_uuLT09vPzH1k Posted at 2023-6-10 07:25
Hi, same here but with an older Mavic Pro. Did you find any solution on this? I tried older Versions of the Go4 App but had no success.
2-26 13:40
