JJB*
Flight distance : 12132231 ft
Hi
Had a look at your flight.
Btw I looked at the flight log and realised there was a input on the controlls that I didnt have controll over. Anyone knows what it could be?
It is ofcourse not possible to know wich RC input was done by you and wich not.....
Flight started with not that much satellites, just 9.
But 9 sats with a number 4 (range 0 - 5) for GPS data is normally enough for a good flight.
In your log the speed calculated by the software and the GPS speed are not in sync, see my chart of your data. Normally the V-xy and V-GPS are showing the same speed. (plus minus little offset value)
Last part of the flight with more receiving satellites both speed were, as normal, in sync. (see the chart for this)
WInd,,,see the barometric height line, coloured red where the software 'measures' wind.
This done by comparison drone pitch and roll angles to achieved speed.
Guess bc the incorrect speed this wind warning is not correct.
Your drone did not loose its GPS reception.
Fly again in area where your have more than 9 sats, see if this issue still there.
cheers
JJB [ Charts by FRAP ; the 'best' software for flightlog analysis ]
