FabioV
Flight distance : 980066 ft
You should consider also the other sources that may operate in the same frequency bands: WiFi, Bluetooth, mobile phones ... As much as the number of devices in the same frequency band increases, you'll probably experience a range reduction. And also the position of the pilots can be relevant: if all the pilots are in the same spot, the situation would be probably very bad, reducing the range a lot. By opposite, having the pilots spread all around may help reducing the interferences.
