Fitting anamorphic lens
574 1 2023-5-17
NZTXXK
Flight distance : 85308 ft
Freewell ( https://www.freewellgear.com/min ... namorphic-lens.html ) recommends to fit "ND filter after putting the drone ON with the Lens". I understand their advise is to fit the base lens (anamorphic or wide angle) with the drone powered off, and once powered on, to then fit ND filter. When I did it last time, RC cautioned me about 'gimbal motor issue' or smth of that kind, since I was holding gimbal in place while trying to fit ND filter. I feel this may damage gimbal eventually. Do you suggest instead to fit everything while drone is powered off, contrary to Freewell advise ?
2023-5-17
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We highly recommend fitting in the lens and the ND filter on the camera before turning on the drone to avoid the camera and gimbal being moved or damaged by hand. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
2023-5-17
