DJI AIR2S high wind warning
1166 5 2023-5-21
Flying Shutter
Flight distance : 1254980 ft
Indonesia
I was flying today when I recieved a high wind warning, it said that auto RTH was unavailable, so if I were to disconnect my drone, would it return to home? or just stay there
2023-5-21
blue_canyon21
Flight distance : 23370489 ft
It would just stay where it is.
2023-5-21
Sean-bumble-bee
Flight distance : 15997 ft
"I was flying today when I recieved a high wind warning, it said that auto RTH was unavailable, so if I were to disconnect my drone, would it return to home? or just stay there"
I would say that the message is probably misleading, RTH should be available but if the wind it too strong then the drone will not be able to overcome it and return to the home.
However, what would happen if you disconnect the drone from the controller depends firstly on the "failsafe" setting, there are three options for what happens when there is a disconnection, see p42, paragraph 3 of the manual,
descend = land,
hover,
RTH.
Note, both land and hover could result in a low battery RTH, the drone might reject the landing site and then hover and a hover will eventually trigger a low battery RTH.Secondly, depending on the set RTH height and distance of the drone from the home point, an RTH could send the drone up into strong wind.
You really should familiarise yourself with the RTH behaviours in practise and the RTH sections of the manual, they are quiote complicated.
2023-5-21
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. A strong wind warning will appear on the app when the air speed reaches 15 m/s (A strong wind prompt will be triggered when wind velocity is maintained at 15 m/s for 5 consecutive seconds.). When a wind prompt or warning appears, we recommend lowering the flight altitude or returning to the home point to avoid accidents. You may also refer to the statement of Sean above regarding the RTH for the DJI Air 2s. Please don't hesitate to reach us if you have other inquiries. Thank you for your valued support.
2023-5-21
Flying Shutter
Indonesia
Ok thanks for the information
2023-5-22
DJI Paladin
Flying Shutter Posted at 5-22 08:41
You are most welcome. Feel free to contact us if you have other concerns. Have a nice day ahead!
2023-6-18
