Drifting While Hovering
1869 11 2015-8-25
douglas
My Phantom 3 Pro is drifting to one side (roll) while hovering. I have done all the calibrations I know of; compass, IMU and gimbal. Does anyone have any idea how to correct this? Little hard to get some of my shots when I am trying to correct for this at the same time. Any insight would be greatly appreciated.
2015-8-25
rayrokni
Flight distance : 8139875 ft
need more info. at what altitude, for example?
2015-8-25
rayrokni
did you do your IMU at an absolutely level surface
2015-8-25
douglas
Actually I found one more calibration; calibrating the controller. I did this. Seemed to help a lot. Still drifts a little, but can tell it's trying to correct itself for the most part when hovering. Should be good for now.
2015-8-25
Nemmo
Russia
douglas Posted at 2015-8-26 12:25
Actually I found one more calibration; calibrating the controller. I did this. Seemed to help a lot. ...
If the RC is not  calibrated properly it beeps on the switch ON . This tell us about bad calibtation.
To hover stable? I don't think it's the reason
2015-8-25
douglas
Nemmo Posted at 2015-8-26 13:35
If the RC is not  calibrated properly it beeps on the switch ON . This tell us about bad calibtati ...
What do you believe is the reason or things to look for?
2015-8-27
Trilithon
rayrokni Posted at 2015-8-26 12:05
But but but.... I was ripped about what a waste of time it was to make a cheap leveling board....
2015-8-27
Nemmo
Russia
douglas Posted at 2015-8-28 01:19
I believe its applies to IMU. May be bad prop balance
2015-8-27
Flight Raptor
Flight distance : 3014675 ft
Nemmo Posted at 2015-8-28 01:47
Agreed....you might wanna just try the spare set of props that came with your copter to see if there is any difference.
2015-8-27
berkebil76
mine moves very little unless the compass calibration wasnt done before each flight. I started doing it everytime now and its elminated the drifting
2015-8-27
m.friedl
Flight distance : 3 ft
Austria
Recalibrate your RC to fix it.Check also if you are in GPS-Mode and not in Atti
Mike
2015-8-27
WBROWN
I am experiencing this same issue. P3 drifts to the right at low altitude (6') with 12 SATS, visual positioning on, new props, fresh IMU & Gimbal calibration (absolutely level surface). Not sure what to do from here.
Ideas?
2015-11-1
