H20T Thermal Mapping with ZOOM camera
548 2 2023-5-22
R_CAPTURE
Flight distance : 10305 ft
Hello everyone,
Does any body knows how to set a mapping in PILOT 2 (or another way) with IR + ZOOM x2 cameras?
The only option today in Pilot 2 is WIDE + IR.
Any Idea?
2023-5-22
DJI Gamora
Hi, R_CAPTURE. Thank you for reaching out. To save photos taken with the zoom camera, tap “Custom Camera” to add and configure a new camera (using the parameters of the wide, zoom, or thermal camera to ensure that the flight route overlap ratio is sufficient). Then, go to the camera view and check “Zoom Video”. Upon successful setting, photos captured with the zoom camera will be saved.
2023-5-26
R_CAPTURE
DJI Gamora Posted at 5-26 02:32
[view_image]
Hello Gamora,
Thank you for your reply.
I finally found the solution : Just select IR when programming mapping (not IR + wide). Then, when in flight, pause the task and select ZOOM + IR in save photos menu.
2023-9-22
