External Mic and Power at the Same Time
3226 26 2023-5-23
djiuser_asuCQJyXPxxK
Flight distance : 120607 ft
Hi,
Does anyone know if there is an adapter for an external microphone and power what works at the same time so charging and microphone. Or is that even possible with the camera ?
Please help
2023-5-23
lutzmix
not possible wih Osmo Action 3
use the Osmo Action one
2023-5-23
Fishycomics
Possible if you know how to make a dummy  battery
2023-5-23
DJI Gamora
Hi, djiuser_asuCQJyXPxxK. Thank you for reaching out. You cannot connect an external mic and charge it at the same time due to a limited USB Port and currently, we don't have any recommended adapter. Osmo Action 3 has a built-in Windproof Microphone, we suggest using it during the time that you have to use while charging. Thank you for your kind understanding and support.
2023-5-26
AZ_DesertRat
USB C Splitter, Dual USB C Headphone and Charger Adapter
https://www.amazon.com/Splitter-Charger-Adapter-Support-Essential/dp/B0882Y5RWG/ref=sr_1_5?hvadid=557458459134&hvdev=c&hvlocphy=9030231&hvnetw=g&hvqmt=e&hvrand=5647032324414801056&hvtargid=kwd-475814153664&hydadcr=18065_13447379&keywords=usb-c%2Bsplitter%2Baudio%2Band%2Bcharging&qid=1685379684&sr=8-5&th=1
Something like this can't be used?
Unfortunate if true.
2023-5-29
Fishycomics
guess its  not happening
2023-5-29
lutzmix
only with action one
with boya/cynova adapter
also wireless!!!
K35. trrs plug
outdoor range max 10m-20m
receiver has an accu/ operating time 4h
voice control dosnt work
2023-5-30
AZ_DesertRat
lutzmix Posted at 5-23 08:35
A review that I read on this item at the B&H Photo web page says it does *not* work with the Action 3 camera.
Looking at the Action vs. Action 3, the USB connector is oriented 90 degrees different in the body of the camera.  That certainly can't help with affixing the adapter in the camera.
2023-5-30
lutzmix
osmo action3
usbc to trrs cable and the receiver work.
my android Smartphone  with filmic
receivei to 3,5 mm headphone jack dont work???
your cam can shutdown but the connection receiver -mic is on .
2023-5-30
lutzmix
with osmo action or osmo action 3 you have a ready mic minimum 4h standby?
mic standy
2023-5-30
skysailor64
Fishycomics Posted at 5-23 09:33
Can you give us a tutorial for doing that?
2023-5-30
Fishycomics
skysailor64 Posted at 5-30 16:29
3-D or   the old school way
2023-5-30
AZ_DesertRat
DJI Gamora Posted at 5-26 07:38
So, there was a design choice with the OA3 camera to not implement the  USB-C Audio Adapter Accessory Mode?
Ref:
https://en.wikipedia.org/wiki/USB-C#Audio_Adapter_Accessory_Mode
https://en.wikipedia.org/wiki/US ... er_Accessory_Mode_2
2023-6-7
djiuser_cwH62tAYKIFV
Thailand
Hopeless when used on a crash helmet at over 30kph.  Very disappointed.
2023-7-25
DJI Gamora
djiuser_cwH62tAYKIFV Posted at 7-25 05:46
Hi, djiuser_cwH62tAYKIFV. We're sorry about this. Please try the setup suggested by other users above. Thank you for your kind understanding and support.
2023-7-31
Fishycomics
need to protect eh external mic, its not a DJI issue
2023-7-31
Loony2392
AZ_DesertRat Posted at 5-29 09:06
I have already tried the adapter. For me, this is a pure software limitation of DJI. I have tested a lot of adapters, some of them do not work, most of them behave in a way that loading is always preferred. This means that an external microphone via splitter works until I connect the charging cable to the splitter, then the OSMO Action 3 switches off the microphone and then switches to charging. When I remove the charging cable from the splitter again, it takes a few seconds and the external microphone is switched on again.
It would be more than nice if DJI corrected this on the software side and made it available for all products as standard. Preferably PD, data & video at the same time like almost every USB-C connection on.
2023-8-1
johansenfoto
Flight distance : 1173379 ft
Norway
I will guess it is hardware related with some kind of protection.
2023-8-1
4wd
Flight distance : 545817 ft
This is another real issue they ought to have improved in the Action 4 - but I won't hold my breath as most likely you will have to buy some special adapter at an inflated price.
If they wanted to help users any adapter should come with it - the real cost is probably about $2
2023-8-2
AZ_DesertRat
Loony2392 Posted at 8-1 22:36
Thanks for the validation for the rest of us that this is a non-starter.
Wager on whether or not the Action 4 has the same limitations to the regulars here?
I suppose we'll all find out in a couple of weeks.
2023-8-2
LookNear
Greece
This is terrible.
So we can record continuously only for the length of one battery??
Is it an action camera??...
This is requirement 5 in a list of action camera architecture requirements...
Sometimes I feel like the product manager thought these camera will be used only in a kid birthday party on the backyard...
Come on DJI. Don't become GoPro!!!
Be the one company that took the action video seriously.
2023-8-29
AZ_DesertRat
FYI...a point-of-reference only.
The Belkin USB-C Audio + Charge Adapter I purchased from Big A didn't have microphone functionality on my OA3 (using TRS lav mic...) but it did on an OA4.
2023-10-26
Fishycomics
the OA4 is getting an external mic and pass over  adapter  ask DJ if that is going to work for the OA3 they are releasing it real soon
2023-10-28
virooo
India
I have never been a fan of DJI locking their products. I own an Osmo Pocket, and it still doesn't have a proper adapter that can use an external mic and charge simultaneously. One reason why I have never bought a DJI product and preferred Insta360s. however, I stumbled upon this video https://www.youtube.com/watch?v=lFppNvyCI-A&t=572s where he confirms that the recently launched Osmo Action Mic adapter works with Action 3. Can someone from DJI please confirm so that people with a lower budget can still purchase the Action 3
1-10 07:22
lutzmix
virooo Posted at 1-10 07:22
you dont need the adapter with the OA3 ,this a slpitter only for 0A4
also dont trust mr wayne and his motovlog examples
my2cent
charge& extern mic. remote multicam
OA yes only mono.       no
OA2 no.                          yes
OA3 no.                          yes
0A4 yes mono& stereo. yes
1-10 11:30
virooo
India
lutzmix Posted at 1-10 11:30
Thanks for sharing. My use cases include charging and using a mic at the same time. Also, I'm unsure what you mean by OA3 doesn't need an adapter. A 3.5 mm mic always needs an adapter.
1-10 22:50
lutzmix
you can try a cheap uspc trrs (samsung) adapter
or use a usbc mic.you dont need the expensive dji splitter for the OA3
dont use the Rhøde lav mic with the OA3
https://forum.dji.com/thread-302789-1-1.html
the smallrig lav mic ca12€
example:
OA3 with
fill light. 20€
wireless mic. 70€
remote. 40€
(all usable also with OA4)
https://youtube.com/shorts/5_fedwzJw5c?si=ZOqpiW_2DDo8ALQT
btw: insta ace pro remote 150€
charging/audio splitter 17€
OA4  audio adapter 37€
remote 79€
1-10 23:35
