DJI Paladin
Hi there. Thank you for reaching out and we're sorry for the trouble. During the flight, the aircraft speed may not reach the maximum speed mentioned in the official manual due to flight power offset affected by environmental wind. Products with obstacle avoidance systems will actively lower their speed after the obstacle avoidance systems take effect. Sometimes, if the environmental light is too bright, the obstacle avoidance systems may recognize the light as an obstacle by mistake, thus slowing down the aircraft.
Solution
1. Please change the flight direction and try again to avoid the influence of wind or light from certain angles.
2. If the aircraft flies slowly in each direction, we recommend that you land the aircraft as soon as possible and go to another environment. We also recommend have a test flight and try in an open environment with less wind and at a lower altitude. (We do not recommend flying your aircraft too high because the higher the altitude, the greater the difference in wind power. As such, the purpose of their testing cannot be reached.)
3. Please check whether the propellers on the drone are damaged or bent. If you found it to be damaged/bent, use new propellers if possible, and try again.
4. Please check and switch the flight mode, and see if the flight speed is slow in different modes. (It is best to check the speed that can be reached in different modes.) |
