Ortho Distortions Following Latest Update
718 6 2023-5-25
DJ Eye
Hello,
Since updating the aircraft, camera and controller to the latest firmware (7.x - the one introduced following the M350 announcement) I've noticed we're now getting a lot of artifacts and distortion in the 2D Ortho images.
We're using the M300 with the Zenmuse P1 camera.
Images prior to update:  https://ibb.co/YTy1sj8
Images AFTER update: https://ibb.co/N7dgkF3
Has anyone experienced this? If so, going to raise it with DJI.
Kind Regards,
Darren
2023-5-25
Panph
Flight distance : 5372365 ft
processed with DJI Terra? update to the lastest 3.7.0?
2023-5-26
fans5b25584c
Flight distance : 24012 ft
I've only flown one oblique volume measurement mission with the new firmware, but I didn't have any trouble
P1, Agisoft Metashape
2023-5-27
DJ Eye
Panph Posted at 5-26 02:33
Yup. Processed in Terra. Updated to 3.7. Also confirmed the RTK was active over NTRIP.
https://ibb.co/W0SF4gw
2023-5-31
DJ Eye
OK, so I've just run the raw images through WebODM and they've come out at the same level of quality with zero distortion or artifacting, so definitely seems like an issue with Terra. Worth noting that while Terra takes just 3 hours to process this dataset, WebODM takes 48 hours! I wonder if the issue is with some of the optimizations Terra is doing to bring the processing time down? Either way, I think we're going to go with WebODM in future - despite the increased processing time. We can just set up a cluster and add more nodes.
2023-6-8
AR_AirPrecision
Flight distance : 2660509 ft
Belgium
DJ Eye Posted at 6-8 05:46
We did some trials with WebODM, and indeed it's slow...especially with P1 output. I wonder if the config can be tuned or it really needs a lot of resources.
The setup isn't light with containers and DBs.
2023-6-8
DJ Eye
AR_AirPrecision Posted at 6-8 20:51
Yup, we've been playing around with the settings. It is possible to skip certain things, but we've captured all our data with a GSD of 0.53cm/px and if we want to preserve that level of fidelity we just need to deal with the extra processing time that creates. It seems to be heavily memory bound.
I'd be very interested to know how Terra manages to crunch the same dataset in 6 hours at that level of detail, though. Pretty amazing, artifacts aside.
We're going to re-provision some old server hardware and set up some processing nodes. Although it  may still take a lot of time, in comparison to Terra, the resultant GeoTIFF is near perfect.
2023-6-9
