TheMann58
Flight distance : 18669501 ft
29MAY2023 UPDATE: I have compiled an edited list of all the future firmware new feature requests for the DJI Mavic 3 Pro that were suggested by the contributors to this forum thread. THANKS to everyone that contributed suggestions to this list.
NOTE: If the DJI firmware and DJI Fly app software programmers were to add 2-3 of these feature requests to each subsequent firmware release, it would add wonderful additional value to this amazing camera and videography drone. This added versatility and functionality would be greatly appreciated by all users of the Mavic 3 Pro, including amateur and professional cinematographers.
Here are the compiled list of new, useful functionality features that are requested to be added in future firmware updates to the DJI Mavic 3 Pro:
- Improve Precision Landing performance to the same exceptional level as on previous DJI drones. NOTE: currently, Precision Landing works well only if the P3Pro is raised vertically to 7M height, hovered for 5 seconds and then flown only a few hundred feet away from Home Point before initiating a RTH in optimal lighting. However, when initiating a RTH from 4000+ feet from Home Point, the aircraft rarely returns precisely to the Home Point and, instead, the aircraft typically starts its descent and attempts to land 3-8 feet, or more, away from the recorded Home Point. The Mavic 3 Pro sometimes attempts to correct its horizontal position during such a RTH descent following a long distance flight, but the aircraft still attempts to land 3-8 feet away from the original Home Point.
- Add Option on the Safety tab of the DJI Fly app for pilots to select between Advanced RTH and Straight Line RTH (which allows for altitude to be adjusted by the pilot during RTH). NOTE: The new default Advanced RTH feature on the M3Pro does NOT allow for altitude to be changed by the pilot during RTH, and Straight Line RTH is only currently implemented automatically (not by the the pilot) during low-light situations.
- Provide functionality for users to manually cycle between the three camera lenses (24mm, 70mm and 166mm) at their native zoom level (1X, 3X and 7X) during Normal flight modes while video is being recorded in Normal mode, including at 4K/60 and 5K/50. In addition, allow this lens switch cycle function to be assigned to the C1, C2 or C3 customizable buttons. NOTE: Currently in Normal flight mode, in order to change the camera lens being used, the video recording must be stopped, the new lens selected, and the video restarted. I do not care if there a couple of blank or noisy video frames during this user-selected lens change, although, ideally, this wouldn't be the case.
- Add functionality to capture a JPG Frame Grab photo while recording video during all normal video modes by pressing the photo shutter button. (Note: This was an extremely useful feature that I used frequently on my older DJI drones. I am sure the advanced processor used in the DJI M3Pro could handle this frame grab photo save during video recording.)
- Add new functionality to allow pilot to manually switch between ATTI (Attitude), where GPS flight stabilization is turned OFF, and GPS flight modes during flight and, further, allow users to assign this ATTI/GPS flight mode change fuction to the C1, C2 or C3 customizable buttons. Audible prompts and screen warning messages should be made by the DJI Fly app whenever the aircraft is in ATTI mode to remind the pilot that aircraft position is now subject to drift with the wind. This added cutomizable button functionality would provide pilots with a valuable and important new safety feature -- the ability to quickly and accurately determine wind speed and direction at the current flight altitude by switching to ATTI mode and then observing the aircraft direction and speed as it drifts with the wind. This can be vital on windy days or when trying to determine if wind speeds aloft are signifcantly different than at ground level as they often are. NOTE: on older Phantom DJI drones, the remote controller had a dedicated switch to select between ATTI and GPS flight modes and I routinely used ATTI mode to accurately determine aircraft wind speed/direction aloft.
- Provide a new option setting to allow the the Battery Level at which a Low-Battery RTH is initiated to be set manually between 10% and 80% by the pilot on the Safety tab of the DJI Fly app.
Minimum level should remain 10% for safety. However, allow the pilot to set this low-battery return level as high as 80%. For example, if pilot knows return flight will be against the wind then it would be a safety enhancement to allow the pilot to set the RTH battery level higher, say at 60%. A reasonable maximum setting might be 80%.
- Add 10-bit D-LOG M color mode to the 7X 166mm camera to unify the availablity of this color profiles across all three cameras.
The 7X 166mm tele camera is great for photos, but lacking in video as only an 8-bit normal color profile is available for the non-Cine version of the P3Pro. It is currently difficult to grade video shot using all three cameras in post because of the lack of a common LOG color profile for all three cameras. - Add the standard D-Log color profile to both the 3X 70mm Medium Tele camera and the 7X 166mm Tele Camera.
- Add a new option to allow pilot to set the noise reduction, sharpness level, contrast level and color saturation level for video on each of the three available cameras.
This would give users the freedom to change theses settings to their liking and improve the video quality and consistency for specific video shoots using one or multiple cameras. - Add ability to capture high-resolution Pano (Panorama) Photos using the fabulous 3X 70mm medium tele camera.
- Enable video capture at 4K 60fps while in Explore mode.
- Enable user selection of all FocusTrack features (Spotlight 2.0, Point of Interest 3.0 and ActiveTrack 5.0) during video capture at 4K 60fps.
- Enable pilots to set and use Waypoints in Night mode.
- Enable pilots in the United States to purchase, install and use the DJI Cellular Dongle on the DJI Mavic 3 series of aircraft to enable Enhanced Transmission mode using 4G LTE cellular control of the aircraft during flight. NOTE: Currently, in the U.S., the DJI Cellular Dongle can only be installed and used in the DJI RC Pro remote (verified by this poster) to provide internet access via cellular service for purposes of browsing the internet, checking flight conditions and authorizations using the DJI Fly app and multiple 3rd-party apps, downloading location-based updates to the Google mapping functionality before or during flight, etc. However, the use of the DJI Cellular Dongle on the Mavic 3 aircraft itself to provide live flight control of the Mavic 3 series of aircraft is currently not allowed by the latest DJI Fly app and the latest aircraft firmware. Adding this functionality in U.S. in VLOS situations would add safety, versatility, and functionality to the Mavic 3 series of professional-quality drones. For example, if a pilot is flying a POV circle around a target, or is active-tracking a moving subject and the aircraft moves into an area with strong signal interference or if the 2.4/5.8 GHz transmission signal is momentarily hindered, the aircraft will enter RTH mode and the video shoot is ruined. The ability of the aircraft to automatically switch between 2.4/5.8 GHz normal transmission mode and 4G LTE Enhanced Transmission mode would ensure aircraft control and video transmission signals are maintained during otherwise challenging signal transmission situations.
Feel free to comment on the usefulness of these requested features and to add your own new feature requests for the DJI Mavic 3 Pro in this forum thread.
