SOLVED: M300 + RC Plus - Says Linked But Isn’t
2471 4 2023-5-30
Steele702
Flight distance : 3876775 ft
Just updated all the firmware on the M300 / H20N / Smart Controller / RC Plus and attempted to link the RC Plus with the drone. The controller will say "link successful" but it's not connected to the aircraft.
Here are my repro steps:
1. Smart Controller off (previously paired controller)
2. Power on RC Plus
3. Select "M300 RTK" in list
4. Power up aircraft - wait ~35 seconds for boot up
5. Press "Link" button in the software UI - verify linking state (beeping)
6. Press and hold PWR button on aircraft for ~5 seconds until it beeps once then release
7. Monitor controller screen for pairing status
Results:
Controller indicates a successful pairing. Indicator light to the left of the battery lights remains red. Entering camera indicates 'Disconnected'. Aircraft power button flashes irradically. Pressing power button ceases flashing.
2023-5-30
Steele702
So I found THIS DJI WHITEPAPER which details how to get the offline firmware that will successfully bind the RC Plus to the M300. HOWEVER, since this is DJI I made a point to read all the fine print. As of end of May 2023, if you install that firmware and bind your RC+, you will never be able to bind the Smart Controller to that aircraft again. My plans were to grab the RC Plus and have my payload operator use the Smart Controller. Nope! So… I’m left with one option; return this M300 that’s only been flown twice to the shop that sold it to me, and then pay the difference on the M350 that *comes* with the RC Plus. Then I’ll have a controller, my payload operator will get to keep his job, and there won’t be any fights over who gets to use the darn bigger screen. Got that, Kyle? RC Plus for us each… so spare me the BS about how “the operator needs the bigger screen since you don’t actually fly because autopilot…” blah blah blah blah. SMH Friggin Kyle…. Anyway, that’s the deal with pairing. Happy flying!
2023-5-30
kanwer
Georgia
I have a similar problem, Did you connect in the end?
7-4 04:04
AR_AirPrecision
Flight distance : 2660509 ft
Belgium
kanwer Posted at 7-4 04:04
Did you install the M300 specific firmware to support RC+?
7-5 04:52
hoss__
Flight distance : 166168 ft
You have the option with the M300: it can be used with RC Plus or it can used with Smart Controller Enterprise. They use different communication protocols so you can't use one of each.
Also if the M300 is updated to work with RC Plus it can later be downgraded to work with Smart Controller Enterprise instead though after you experience the RC Plus would probably want to stick to it.
Guide generally covers everything: https://dl.djicdn.com/downloads/ ... and_M350_RTK_EN.pdf, but latest firmware/versions is available on the downloads page https://enterprise.dji.com/matrice-300/downloads.
Note make sure on the RC being used you select the proper aircraft to link to (M300, M350 etc...).
7-5 14:20
