Aurgelme
Flight distance : 2730 ft
Norway
I have got hold of some motors, some have been in salt water, some just hard to rotate, to investigate what is wrong with them, as well as experimented with different ball bearings in steel and all ceramic.
Working on rewriting software for an esp32-c3 to measure current draw, rpm, lift and vibrations. I hope to finish it in the autumn, as I am in a learning process on this processor.
But one thing I found out after testing the engine that was stuck, there were no fragments in them, but the grease in the ball bearing and the lower slide bearing was very thick/hardened, so the oil fixed it on this engine as well.
The oil I have used is 1up Racing Clear Bearing Oil - 8ml
EDIT
The tester is based on this dynamic propeller balancer, with some modifications
Dynamic Propeller Balanser build.
Dynamic Motor and Prop Balancer
