Brazil
Hello,
I'm from Brazil, I have an M300 RTK with Zenmuse L1.
After the latest Smart Controller, M300 and L1 updates, I am no longer able to perform LiDAR mapping flights.
I import the KMZ, configure the flight parameters (see below) and when I press play on the flight plan to be executed, two alerts appear with the following messages: "Creating flight route folder failed" and "Failed to save Payload Settings. Reconfigure before executing flight route".
Error
I thought it was a problem with formatting the memory cards, I tried to format them in all possible standards (Ex-FAT, FAT-32 and NTFS), but nothing helped. I tested the following memory cards: SanDisk Extreme U3 A1 32GB, SanDisk Ultra C10 32GB, SanDisk Extreme U3 A2 128GB and Lexar C10 U3 64GB.
Unfortunately the problem persists.
Parameters used:
Zenmuse L1 LiDAR Mapping
Point Cloud Density: 157 point/m²
GSD: 2.73 cm/px
Safe Takeoff Altitude: 100m
IMU Calibration: Selected
Terrain Follow: Selected
Terrain Follow Height: 100 m
Takeoff Speed: 15 m/s
Speed: 6 m/s
Course Angle: 313°
Side Overlap: 20%
Forward Overlap: 70%
Margin: 0m
Photo Mode: Timed Interval Shot
Return Mode: Triple
Sampling Rate: 160 KHz
Scanning Mode: Repetitive
RGB Coloring: Selected
Firmware Versions
M300: 07.00.0100
Smart Controller Enterprise: 07.00.0100
Zenmuse L1: 07.00.0110
Left Battery: 01.02.05.44
Right Battery: 01.02.05.44
Please, anyone who is experiencing the same problem, comment here if there is any solution, as I have already tried to downgrade to a previous version of L1 but the system does not allow me to.
