Preplanned route
782 5 2023-5-31
DaveInTexas
Flight distance : 269190 ft
Hoping it’s easy to do this;
Tomorrow I need to survey 200acres for lost cattle.
It’s a ~ rectangle, about 4000’x2500’ all flat except one corner goes up a hill maybe 100’ from the rest.
How do I tell the drone to take off, head to a nearby corner, then to the other 3 corners, back to the first corner then ‘home’?
I can get the coordinates off googleearth.
2023-5-31
Ranjan
India
You can try dronelink beta app which is meant for doing such work.
https://support.dronelink.com/hc ... -Beta-Test-Feedback
2023-5-31
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Regretfully, the DJI Mini 3 Pro does not support surveying and mapping functions. The reason for this is that the surveying and mapping function has high requirements for the aircraft’s positioning system and camera lens. You may want to check our Enterprise product if you want to perform the said feature. Thank you for your understanding and support.
2023-5-31
DaveInTexas
Thank you
I was able to zoom around the property and find the corners visually.
Lots to learn!
2023-6-1
DJI Paladin
DaveInTexas Posted at 6-1 09:08
Thank you
Lots to learn!
You are most welcome. Please don't hesitate to reach us if you have other inquiries. Have a nice day ahead!
2023-6-15
djiuser_g64plawv65Ce
Flight distance : 107218 ft
Durning performing any of the manovoures below at the end of them does the drone return to its starting point ? Dronie, Helix, Rocket, Circle, Boomerang, and the Asteroid
2023-6-25
