Gimbal control with DJI high bright monitor + combo grip
1064 5 2023-6-1
Aeriallive
Flight distance : 4054803 ft
Hello everyone,
I have a DJI high bright monitor with grip to control the gimbal of the Inspire 3. But I can only control the focus with the wheel, not the movement of the gimbal with the joystick. Any idea how to fix this?
2023-6-1
Aeriallive
SOLVED: I didn’t notice the small lock switch on the top was locked. Now everything works just fine.
2023-6-1
Kike
Flight distance : 3309642 ft
Portugal
Do you know if there is any way to change the orientation of the sticks?
In order to push up and make the camera look down?
2023-6-1
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We're glad that you already managed to isolate the issue that you experienced. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
2023-6-1
fansba3b7009
Flight distance : 314908 ft
Austria
does gyro controle with the high bright monitor work as well to move  the gimbal pan/tilt/roll
2023-10-3
JJungPhoto
Flight distance : 946362 ft
fansba3b7009 Posted at 2023-10-3 06:36
It used to work. But they removed the feature from the IP3 a rep just told me... kinda strange they'd remove it?
4-29 20:31
