Sudden Altitude Drops
629 17 2023-6-4
BrianKushner
Flight distance : 41420253 ft
Anyone else experiencing sudden altitude drops? I've had it happen a good amount of the time.  Here is an example.
In 10 seconds the drone drops from 103 feet to 51 feet without touching the stick.
5:23 to 5:33.
https://www.phantomhelp.com/LogViewer/5HDZHH4OFZPSG7OF1WD6
2023-6-4
GaryDoug
Flight distance : 1264639 ft
I see that. Sudden downdraft? Any unsettled weather in the area? Looks like the remote lost control for a while. Maybe intermitent motor failure or prop damage? Our best analyists will be along to help more than I can.
I have never seen anything like that with my standard M3.
Just as an excercise, manually turn all 4 motor props. Does any have some resistance?
2023-6-4
Suren
Flight distance : 13438648 ft
New Zealand
Seems that this one is giving you issues Brian, maybe just get it replaced at the dealer
2023-6-4
Sean-bumble-bee
Flight distance : 15997 ft
Has anyone looked at the battery currents? 24A in several places, that's quite a draw.
2023-6-4
BrianKushner
GaryDoug Posted at 6-4 20:38
It's happening a lot and weather is fine. So are the props.
2023-6-4
BrianKushner
Suren Posted at 6-4 20:50
Yeah that's an option but I hate having to do that. I have to return one before they send another then I'm without the drone etc. Also, like the timelapse issue others are having so I doubt it's the bird.  Past experience tells me the replacement will do the same thing.
2023-6-4
BrianKushner
Sean-bumble-bee Posted at 6-4 21:41
Never an issue on the M3..same batteries..
2023-6-4
TonyPHX
Flight distance : 11229610 ft
That would concern me a lot.  That is a lot of $ in the air dropping altitude at will.  I think I would do some more testing over land and make a determination if it needs to go in for service or not.
2023-6-4
Suren
New Zealand
BrianKushner Posted at 6-4 22:25
Mine seems to fly rock steady hence maybe it could be faulty. I know you have done the IMU calibration etc so it the bird is still doing that send it in for a replacement
2023-6-5
DJI Gamora
Hi, BrianKushner. Thank you for reaching out. Please try the following troubleshooting steps below for this issue:
• Please check whether the flight environment is in a high altitude area. The higher the attitude, and thinner the air. Thin air will affect the aircraft’s propulsion, resulting in propulsion overload, sudden descent when hovering, unstable flight, etc. Please refer to the Max Service Ceiling Above Sea Level on the official DJI website. After repeated tests, we have determined a safe flight altitude range for the aircraft.
• Check whether the propeller is in good condition.
• It is recommended to calibrate IMU.
• Ensure that there is not installed a third-party payload, such as a third-party propeller guard, landing gear, etc.
• Kindly provide us with the recorded video or the flight records to confirm the aircraft’s sudden descent when hovering.
• Please provide the flight controller data for further checking.
For Flight Controller Data Export:
Step I: Please connect the aircraft to a computer with a USB-C cable. Launch DJI Assistant 2 (Consumer Drones Series). You may download it from this link: (https://www.dji.com/downloads/so ... sumer-drones-series). Tap the Aircraft icon.
Step II: Go to the Product Page. Select “Log Export” on the left menu. Then, select the required time point data and finally select “Save to Local”.
Step III: After “Download Complete” appears, it indicates that the data has been saved locally.
Step IV: Then save the .DAT file format.
Please keeps us posted. Thank you.
2023-6-6
BrianKushner
It's not high altitude. 23 feet above sea level. As I mentioned I've flown 10 of your drone in this area daily with no issues.
2023-6-6
Burt37
Flight distance : 4009 ft
What does it mean:
"Remote controller in high interference environment. Manually adjust flight route or return to home (CODE: 80014).; RC Signal Interference."
At 5,27.7...
2023-6-6
GaryDoug
Burt37 Posted at 6-6 12:09
What does it mean:
It means the remote is issuing commands and being without confirmation. Maybe check the remote for a problem.
2023-6-8
Burt37
GaryDoug Posted at 6-8 21:45
So why are you surprised of the sudden altitude drop then?
There are several warnings like that in the log...
I don't get it?
2023-6-8
JJB*
Flight distance : 12260774 ft
Hi Brian,
Did you actually saw your drone loosing height or just noticed this drop looking at data ?
In Sport mode, rapid RC fdw/aft inputs DJI drones do have some problem with keeping height steady.
RC fwd stick stick from full fwd to zero input, drone rapid from pitch down to pitch up, followed shortly by full stick fwd and stop again.See my chart of your data.
The airflow, thus pressure, in and around the craft is not steady at rapid up down pitching, so the indicating baro height does not always represent the actual flying height.
The IR height sensor did measure few times during this baro height descent alsmost the same value.
So did it really lost (so much) height?
High power draw bc full power asking in sport mode. see chart. so imo 24 amps looks normal.
cheers
JJB   [ Charts by FRAP ; the 'best' software for flightlog analysis ]
2023-6-10
BrianKushner
JJB* Posted at 6-10 07:25
Hi Brian,
Yes I saw it dropping. One one other time I was flying along in Cruise Control and I noticed suddenly the ground was much closer. I checked altitude and it said 100. I took the drone out of Cruise, toggled the stick to rise up and the second I toggled the stick altitude went from 100 to 50. So it was 50 already but was reporting 100. I believe it's only happened in Sport mode now that I think about it.
2023-6-10
JJB*
BrianKushner Posted at 6-10 10:20
oke, but imo hard to tell how much it dropped.
Fly in sport mode above a solid surfcae withing IR height range and go few times from full forward to stop ect.
Check the baro height indication versus the IR height values in the log.
In sport mode with rapid picth changes (even worse pitch and yaw same time) and see height fluctuattions.
cheers
JJB
2023-6-10
GaryDoug
Burt37 Posted at 6-8 23:43
Don't blame me. I am just the messenger ;-)
2023-6-10
