3 Problems with M3T (ATTI, Gimbal, PinPoints)
968 3 2023-6-9
pspec
Flight distance : 2570446 ft
Switzerland
Hello
With the current firmware from 02.03.2023 I have the following 3 problems:
1. Before I fly a mission and when I cancel a mission, I can switch to ATTI mode. But when I finish a mission and switch to ATTI mode, it does not become active. This is a safety feature and should work. The same procedure works for M30T.
2. When I fly a waypoint mission and press the physical pause button, most of the time the gimbal does not stay at -90 degrees but swings up slightly and stays there. You then have to manually bring the gimbal back down.
If you press the pause button on the display, this does not happen.
(Gimbal calibration does not solve the problem)
3. If the RC Pro is switched off, the stored PinPoints in Pilot 2 are deleted. This is a very important function for search missions.
Why has this not been fixed for 3.5 months since the last firmware?
2023-6-9
ihmunro
Flight distance : 431437 ft
It looks like it hasn't been fixed because people like to debate the issue rather than fixing it
2023-6-18
pspec
Switzerland
No response from DJI.
Too bad DJI only gives answer in the forum when you write something positive.
2023-6-19
pspec
Switzerland
Two out of three problems were fixed with the firmware update of 29.08.2023.
Point 1 and 3 are now ok.
DJI only needed 6 months for this ;-)
2023-8-29
