smbishop
Flight distance : 1859232 ft
HGDC84 Posted at 6-11 05:27
Also, there is an Ulanzi adapter type OP-2 that can be used with the Pocket 2, if you remove all the adapters from the bottom of the Pocket 2 before inserting. It also allows charging the Pocket 2 at the same time without the DIA Handle eating up power.
Interesting. Do you know if the Do it All Handle is consuming power if you are not wirelessly connected to the Mimo App? I am wondering if I would get a longer timelapse without the Do It All handle attached. Normally I start the timelapse with the phone connected, then turn off the phone. |
