HDMI Input does not work with video capture device
2032 2 2023-6-10
peteredoc
Flight distance : 204140 ft
I have a standard HDMI Capture Card which takes an HDMI signal and turns it into a USB signal that goes into my computer (in my case a Mac Air M1).  I have tested this card with HDMI output from a laptop and a Samsung Galaxy, and it works.  My computer gets the live video stream.
However, when I connect it to the HDMI output from the DJI RC-Pro controller, it does NOT work.  I get the "rainbow of death" .
* I have verified that the HDMI output on my RC-Pro works - when I plug it into a monitor, it displays the drone's camera image. This also proves that my HDMI cable is good.
* I have verified that the HDMI Capture card works - when I give it video from another HDMI source (like my other laptop or android phone) it works.  * I have also tried with USB-video output, but ran into another problem (see https://forum.dji.com/forum.php?mod=viewthread&tid=292354)
So there must be some problem in the way that the RC-Pro talks to the capture card.  Has anyone experienced this or does anyone understand why this might happen?
--- Mandarin translation courtesy of GPT-4.  May have errors. ---
我有一个标准的HDMI采集卡,它可以将HDMI信号转换为USB信号,然后输入到我的电脑中(在我这里是Mac Air M1)。我已经用笔记本电脑和Samsung Galaxy的HDMI输出测试过这张卡,它是有效的。我的电脑可以接收到实时的视频流。
然而,当我将其连接到DJI RC-Pro控制器的HDMI输出时,它就不起作用了。我得到的是“死亡彩虹”。
* 我已经确认我的RC-Pro的HDMI输出是有效的 - 当我将它插入一个显示器时,它显示出无人机的摄像头图像。这也证明我的HDMI线是好的。
* 我已经确认HDMI采集卡是有效的 - 当我从另一个HDMI源(比如我的其他笔记本或安卓手机)给它视频时,它是有效的。
* 我也尝试过使用USB视频输出,但遇到了另一个问题(请参阅https://forum.dji.com/forum.php?mod=viewthread&tid=292354
所以,RC-Pro与采集卡之间的通信方式可能存在某种问题。有人遇到过这种情况吗?或者有人明白为什么会这样吗?
Rainbow of death
Rainbow of death
2023-6-10
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. We will coordinate this concern of yours to our relevant team for further clarification. Kindly please provide us a picture showing how you setup the DJI RC Pro connected to the external device using the said accessory so we can check it further. Please keep us posted. Thank you.
2023-6-10
peteredoc
I found the solution - It turned out I had to adjust the HDMI Resolution on the RC-Pro (Settings -> Display -> HDMI -> HDMI Resolution), then after that, video capture worked.
What was odd was that - if I recall correctly, It was originally set to 1920x1080, and not working.  Then when I changed it to 1280x720 it worked, but then I changed it back to 1920x1080, it still worked.  At 3840x2160, it does not work.
Here is a video showing the problem and the fix: https://photos.google.com/photo/ ... 6CTLwf-GnYHdimbulnP
And here is the proof that it works.
2023-6-11
