DJI Gamora
Hi, djiuser_A7rIv2AJ1Hy6. Thank you for reaching out. Please try the following steps below:
1. Check whether the battery level has reached 100% (All four bars of the battery level indicator are on).
2. Check if the charged method is correct. Make sure the charging cable is plugged in tightly, and try plugging it in again.
3. Check the LED on the remote controller and confirm if it is in the charging state. If yes, please try charging for 2 hours to see if the power increases. If it still cannot charge, it is recommended to replace the charger and charging cable.
If the charging continues to fail, please provide us a video showing the issue for further checking. Thank you. |
