Default Folder Structure, Foldername & Filename in M3T
922 0 2023-6-15
KenSO3
Got the new M3T and found that the folder structure/filename of M3T was different from Mavic3/Mini3Pro.
Q: In M3T, the default settings of ‘Create Folder’ was ‘DJI_YYYYMMDDhhmm_XXX_’, the commonly used 100Media folder was no longer available?
Q: In the exif/xmp metadata, the field ‘Model’ was assigned with “M3T” and replaced the usual FC(4 digit number)?
Also, the naming convention of files seems partially adopt the ‘Create Folder’ and suffix is added as DJI_YYYYMMDDhhmmss_nnnn_V & _T.jpg automatically.
Q: Can I set the naming convention of images separately?
Q: The thermal image will be generated simultaneously in default? Those _T.jpg files are classified as r.jpeg (cannot find the option ‘Radiometric JPEG’ in App)?
2023-6-15
